Post by milly on Mar 29, 2023 13:01:02 GMT -5
sinfull
Post by sinfull on Mar 29, 2023 13:32:09 GMT -5
I would seriously ride that, love it and can't wait for you to get it
Post by aeroxbud on Mar 29, 2023 14:45:25 GMT -5
You're going to need a bigger trailer.
Post by milly on Mar 29, 2023 15:26:27 GMT -5
That is the conundrum getting it back. Something that fits the towbar that lifts the front wheel off the ground me thinks 🤔
Post by FrankenMech on Mar 29, 2023 15:35:34 GMT -5
I think you would enjoy it, but it will take a lot of work to get it going reliably. It may not be worth that £500. That radiator puke can may be cute but you can do much better. It may need a good roll bar installed. Trikes are inherently unstable. It will cost more money for a reliable machine. You might need the mechanics in the shop to look it over.
A bigger trailer AND a bigger tow vehicle may be needed. It won't be cheap to transport from up North.
Post by FrankenMech on Mar 29, 2023 15:44:45 GMT -5
Lifting the front wheel of the ground may lift your car's front wheels off the ground. That machine is probably heavy. Towing safety is a concern.
Post by milly on Mar 29, 2023 16:55:01 GMT -5
You are indeed correct on that point. I found out he has a thing to raise it off the ground on the front wheel but would need to check the nose weight as my towbar spec is about 60 kilo's whatever that is in pounds approx 130 lbs I would think. Tomorrow I will get back in touch.
Post by oldgeek on Mar 29, 2023 18:29:31 GMT -5
What a lovely death trap!
Post by milly on Mar 30, 2023 12:45:13 GMT -5
Well against my better judgement I have decided against getting it. Must be getting sensible in my old age 😊
Post by jackrides on Mar 30, 2023 14:19:08 GMT -5
Sometimes younger and dumber is more fun. Can you find out what your mate had for dinner before he designed that front end?
Post by FrankenMech on Mar 30, 2023 14:22:50 GMT -5
2 liters of single malt.
After years of wear all those joints would be worn and the frame members cracked in many places. The thing probably vibrates so bad that it would explode at any speed over 40MPH.
Post by FrankenMech on Mar 30, 2023 14:29:41 GMT -5
Well against my better judgement I have decided against getting it. Must be getting sensible in my old age 😊 It IS your better judgement that has prevailed. Old age and experience has bettered youth and stupidity once again.
