Post by ronnie on Apr 1, 2023 2:53:43 GMT -5
Hi guys !
I think, im not newbie in this "category" , but i would like to kindly hear your ideas, since im totally lost and disappointed now... The topic is bit more complex and i try to describe everything. If you dont have time or energy for reading, please skip.
Scoot/Engine : Keeway, 1E40QMB, classic chinese 2stroke copy of Minarelli, cca 4000KM
Issues :
First issue i realized after buying the scoot for my wife was, that the scoot idles on cold starts very low. Im familiar with Idle speed adjustments, but there isnt the "choke" effect of revving up for 2-3minutes after cold start and then settling back to desired to idle. If i match the idle for cold start to be high enough, then after warming up the idle is even higher (revving, moving rear wheels etc...). Besides mentioned issues, the scooter start in every condition, everytime.
Workarounds :
- Changed e-choke 3x (aftermarket, another aftermarket, factory). When i mounted-replaced the choke last time for new factory choke, the cold start appeared to be OK, so it revved up after start and behaved as should... Maybe for couple of starts. Then the upper mention situation repeated and still remained.
- Changed ignition to fully new (factory)
- Changed carb-intake hose to new
- Changed airbox and filter to new (was-is factory)
Second issue is bogging (rich) after full throttle for some time. Lets say, you are running full speed on straight approaching roundabout. Inrelease the throttle and slow down a bit, then apply again throttle to accelerate. This is the point where maybe the scoot start to bogging for a second, no power, the runs as it should. It is uncomfortable and dangerous. This "overfilling" appears also if you let scoot run on idle for 20-30seconds and would accelerate (on intersections, or you have to open the garage doors). The first seconds are just bogging
Workarounds:
- The only way i can avoid bogging is fully unscrewing the mixture screw (the screw of course remain in the carb, but is unscrewed to the max). The trouble with this workaround is, that during acceleration is a huge lack in mid rpm. So the scoot accelerates without hesatition on full throttle, catches quickly some rpm and speed, then huge fading in power and acceleration appears between 40KM/h-50KM/h, and after 50KM/h it goes again great till cca 70KM/h (42MP/h).
- Rejetting Main Jet from 55 to 64 (55, 58, 60, 62, 64). It doesnt matter which main jet i use, if i touch mixture screw, bogging appears. My
Idea was, that maybe during WOT is engine overfilled and that causes bogging on throttle release. It sadly doesnt work, since also with jet 55 happens the same and the power drop in upper described range and also on highend is huge here.
- Played with needle position, but the only result was loosing power on leaner position
- Changed factory carb to Arreche 17.5mm. Bogging was still there with smallest pilot and main jet that company manufactures ! Experienced also troubles with starts. Scooter start only once after assembling everything together. After some running you are able to start the scoot after covering the air filter BUT only for a second ! If you cover it longer, it overfills the engine and it also wont start. If you didnt cover the airbox, it also wont start. Happens with every single size of main and pilot jet. I dont understant what causes this trouble here, since the scoot is running rich as described ! Why i need to cover the airbox for specific time to start ? My idea was, that engine cannot suck in the mixture for some reason. But why only after first start ? However the throttle response, running, vmax, torque was absolutely improved and im really sad that i cannot run this carb.
Im totally lost now guys...
If you have any idea, please share it with me.
Thank you very much !
Issues :
Workarounds :
Workarounds:
