Post by captincvmn on Apr 1, 2023 14:56:26 GMT -5
two stroke Chinese minarelli, let’s see what parts I can harvest off of this POS
Post by oldgeek on Apr 1, 2023 15:27:04 GMT -5
You may have a short case 100cc setup there.
Post by captincvmn on Apr 1, 2023 16:27:00 GMT -5
Side of the four wheeler says 50cc, spark plug has been out for a long time. Variator clutch and TD all look very good. It even had the speed limiting spacer in the middle of the variator which this is the first I’ve seen one. Thunderstorm stopped me from digging further
Post by captincvmn on Apr 1, 2023 16:28:01 GMT -5
Note the NOS grease on the bearing inside the cover
Post by aeroxbud on Apr 1, 2023 17:15:34 GMT -5
Looks surprisingly good inside.👍
sinfull
Post by sinfull on Apr 2, 2023 15:35:03 GMT -5
Clean it up and build it as a spare engine, easier to bolt in a fresh engine if and when yours fails. Mount bolt, shock bolt and you can have a fresh engine in 20 mins or less 😆
Post by captincvmn on Apr 2, 2023 16:43:24 GMT -5
Clean it up and build it as a spare engine, easier to bolt in a fresh engine if and when yours fails. Mount bolt, shock bolt and you can have a fresh engine in 20 mins or less 😆 Trouble is that the four wheeler is chain drive. I do like what you’re thinking though.
Post by rollingbender on Apr 2, 2023 16:48:46 GMT -5
Could it be as simple as replacing the current gear final output with a scooter axle/output shaft?
Post by oldgeek on Apr 2, 2023 17:46:51 GMT -5
Could it be as simple as replacing the current gear final output with a scooter axle/output shaft? Proper gears can be sourced, but remember it is a short case mina so only 10" wheels will fit it.
Post by captincvmn on Apr 2, 2023 17:48:44 GMT -5
Post by aeroxbud on Apr 2, 2023 18:16:56 GMT -5
That starting motor looks very new. Score! 👍
Post by captincvmn on Apr 2, 2023 19:05:30 GMT -5
Gross
Post by rollingbender on Apr 2, 2023 19:26:03 GMT -5
Gross That’ll buff right out!🤣
Post by FrankenMech on Apr 2, 2023 20:03:17 GMT -5
If the tires or wheels are good they may be worth some $$.
A hose, compressed air, and some electrical parts cleaner will clean that stator up. Parts need elbow grease.
Post by captincvmn on Apr 3, 2023 5:38:45 GMT -5
Tires and wheels are shot. It’s been a good experience taking this apart though. I split the cases, first time. Learned some things.
