Post by scooterguy42 on Jun 18, 2023 7:20:12 GMT -5
Post by aeroxbud on Jun 19, 2023 3:35:26 GMT -5
Yes it's number 32. You have probably gone up too much on the jet size. That's a big jump in size you have used.
Post by scooterguy42 on Jun 19, 2023 4:10:52 GMT -5
I put in a 115 now. It runs much better. But im noticing a high idle. When im trying to adjust it nothing happens. Only if i tighten it further the idle gets higher.
Post by aeroxbud on Jun 19, 2023 4:45:15 GMT -5
Is your exhaust a straight through one? Or does it have a baffle fitted? That is still a large jet.
Post by scooterguy42 on Jun 19, 2023 6:35:17 GMT -5
Its a straight through one.
What jet is reccomended when the stock one is 97,5? 105 or so?
I also have a DNA filter in the stock airbox.
Post by aeroxbud on Jun 19, 2023 7:43:46 GMT -5
Its a straight through one. What jet is reccomended when the stock one is 97,5? 105 or so? I also have a DNA filter in the stock airbox. Is that a pod filter? They can cause all sorts of tuning issues. You would be better off using a standard air box. I would probably try something like 105 if it's just a filter in the air box.
Post by scooterguy42 on Jun 21, 2023 6:35:22 GMT -5
Its a straight through one. What jet is reccomended when the stock one is 97,5? 105 or so? I also have a DNA filter in the stock airbox. Is that a pod filter? They can cause all sorts of tuning issues. You would be better off using a standard air box. I would probably try something like 105 if it's just a filter in the air box. Its not a pod filter. Its a replacement "Sport" filter for the stock airbox. I have now tried 115,110,105,100. And then i tried the stock one (97,5 as i presume it is,its not branded) And now its not running good at all. If i go full throttle it starts bogging. And at take off i can hold the scooter from running. Very weak. I have a replacement carb laying around. Its the same size (26mm) but it dont look exactly the same. I will try that one,but then i need to - Is this a vaccum inlet? There are one on the other side but that is for the gasoline.
Post by scooterguy42 on Jun 21, 2023 6:38:57 GMT -5
Can i just plug it?
