kevino
https://www.youtube.com/watch?v=04dSGwAssRA
Post by kevino on Jun 28, 2023 18:10:32 GMT -5
The manual says torque the head bolts to 10 ft/lbs but I went to 15. It felt okay while using the torque wrench. Any ideas?
TIA, kevin
pili
Post by pili on Jun 28, 2023 18:26:05 GMT -5
I torque mine to 150 inch pounds which is 12.5 ft lbs. Over 20k miles. You should be fine.
Post by GrumpyUnk on Jun 29, 2023 13:15:11 GMT -5
If you search enough you can find multiple torque values for the fasteners. I think you will be fine. If desired, you could loosen all four, and then retorque to a value you like. I think I overtorqued the first one I did but it seemed to be okay after. If you do re-torque, do not disturb the head or cylinder as a leaking gasket is a possibility. tom
pili
Post by pili on Jun 29, 2023 16:04:44 GMT -5
You might also check torque on the exhaust to cylinder bolts after each of the first two or three heat cycles.
