kevino
https://www.youtube.com/watch?v=04dSGwAssRA
Post by kevino on Jun 29, 2023 10:17:08 GMT -5
When I ordered the BBK I'd forgotten about this packet. Any idea what they are and where these items should go? TIA, kevin
Post by billwill on Jun 29, 2023 10:27:47 GMT -5
When I ordered the BBK I'd forgotten about this packet. Any idea what they are and where these items should go? TIA, kevin I believe those are exhaust studs/bolts and gasket. Can't speak for the rubber bit...
kevino
Post by kevino on Jun 29, 2023 10:48:07 GMT -5
Thanks, the round copper piece reminds me of the seal on a car engine drain plug. But not even a clue about the rest.
kevino
Post by kevino on Jun 29, 2023 11:43:02 GMT -5
I think the big rubber band fits into a groove on the underside of the head cover assembly. Otherwise there's no gasket to keep oil from leaking.
Post by billwill on Jun 29, 2023 12:44:32 GMT -5
Ahh yes, assuming this is a water cooled setup, that makes sense.
kevino
Post by kevino on Jul 1, 2023 13:51:56 GMT -5
Ahh yes, assuming this is a water cooled setup, that makes sense. I didn't know there were water-cooled motorbikes.
Post by aeroxbud on Jul 1, 2023 14:02:48 GMT -5
Ahh yes, assuming this is a water cooled setup, that makes sense. These are air cooled. But it's a four stroke. It has oil in the head to lubricate the camshaft and followers.
Post by billwill on Jul 1, 2023 14:22:14 GMT -5
Ahh yes, assuming this is a water cooled setup, that makes sense. These are air cooled. But it's a four stroke. It has oil in the head to lubricate the camshaft and followers. Ahh right on. Makes sense!
Post by classacted on Jul 1, 2023 20:21:19 GMT -5
the round 'ring' is your exhaust gasket. you probably have two studs to go with the long nuts that hold the muffler to the cylinder.
kevino
Post by kevino on Jul 2, 2023 19:45:46 GMT -5
Motor is mostly done. The starter works but engine not firing. I checked the sparkplug is good. The problem is in the carb, I imagine.
claydoh
Post by claydoh on Jul 3, 2023 6:59:36 GMT -5
The short studs and the long nuts are for the muffler. The long studs are for the intake manifold. The copper ring is one style of exhaust gasket. The rubber gasket is for the valve cover.
