Post by fondbcn on Sept 8, 2023 10:40:32 GMT -5
Hi,
I found on internet that the pwk carb cools down the engine at full throttle (because of the additional power jet), so is it a healthy tuning for a 4 stroke mini scooter ?
Post by tomyoder66 on Sept 15, 2023 4:35:15 GMT -5
I have used these carbs and haven't had a problem...until now. The carb I have on my bike has been going strong for almost 2years. It's a 21mm with a9 cam 50mm piston and jug. I'm in the middle of troubleshooting. But a new carb seems way easier. But hey, 2 years ain't bad.
br4inl3ss
Post by br4inl3ss on Oct 15, 2023 9:48:15 GMT -5
power jet is nothing but problems. find me one that REALLY run it. be it IRL or on youtube. not those people saying they do but dont.
yes pwk / phbg is better for cooling. its not power jet related tho. its venturi related ( i guess ). i dont have pwk ( because i was afraid ill have the widely known fuel starvation issue ) but a phbg.
my over-lean jetted 19mm phbg make my engine run cooler than it ever did, with both properly jetted and overly jetted CVK carb. from 17.5 to 24mm. on the keihin 24, i tried a 130 main jet. thats way too big. it was perfect with a 105. so imagine how much fuel was there to cool the engine. with my 19mm phbg, way too small jet ( 50 while its perfect with a 102 ) was running 7F cooler than with the over jetter 24mm cvk. i dont know if you realize how huge this is of a difference between cvk and phbg just for cooling.
br4inl3ss
Post by br4inl3ss on Oct 15, 2023 9:49:18 GMT -5
I have used these carbs and haven't had a problem...until now. The carb I have on my bike has been going strong for almost 2years. It's a 21mm with a9 cam 50mm piston and jug. I'm in the middle of troubleshooting. But a new carb seems way easier. But hey, 2 years ain't bad. did you have quick throttle action problem ? ( be it 1/3 of full throttle, same happen to any throttle, just on fast action ) ? did you change needle ?
sinfull
Post by sinfull on Oct 17, 2023 2:04:05 GMT -5
I live and die with cp21 carbs, never ever had a problem with a cp carb, more expensive than a Amazon carb sure is, but you pay for the quality
