Naraku
Nov 28, 2023 19:01:37 GMT -5
via mobile
Post by dwint on Nov 28, 2023 19:01:37 GMT -5
I have my idle screw all the way in and it will idle so low it shuts off.I dont know if the enrichener has any effect but the brass part from the enrichener was stuck and had to drill it out.If I drilled too deep would that effect anything?
pili
Naraku
Nov 28, 2023 19:35:06 GMT -5
via mobile
Post by pili on Nov 28, 2023 19:35:06 GMT -5
You’re talking about the plug over the air screw? It would damage the head of the screw and make it difficult to adjust.
Naraku
Nov 28, 2023 20:06:31 GMT -5
via mobile
Post by dwint on Nov 28, 2023 20:06:31 GMT -5
The idle screw that raises the throttle slide
pili
Naraku
Nov 28, 2023 23:47:14 GMT -5
via mobile
Post by pili on Nov 28, 2023 23:47:14 GMT -5
I’m sorry the only type of idle speed screw I’ve seen is a stop that mechanically limits where the throttle lever stops. The cold enrichment on my Zuma is a timed unit that eventually drops a needle to stop extra fuel from being added. I don’t understand what you drilled out.
Naraku
Nov 29, 2023 8:24:24 GMT -5
Post by dwint on Nov 29, 2023 8:24:24 GMT -5
when i went to replace the enrichener with a new one the brass part remained in the carb.I dried everything to get it out .I measured the new brass enrichener and sized it up with the drill bit to remove it.It will idle untill it starts to warm then shuts off.
pili
Naraku
Nov 29, 2023 14:06:40 GMT -5
via mobile
Post by pili on Nov 29, 2023 14:06:40 GMT -5
Indeed if you drilled through the brass into the carb body you need to remove the new brass piece and fix that, or if the new brass piece doesn’t fit tightly it would leak around the outer edge causing it to be rich. Permatex and JB Weld both make good epoxies for gasoline applications. That would go along with your symptoms. Does your enrichener use a needle? It possibly might not be dropping enough.
Post by FrankenMech on Nov 29, 2023 16:11:48 GMT -5
Buy a new replacement carb.
pili
Naraku
Nov 29, 2023 19:07:42 GMT -5
via mobile
Post by pili on Nov 29, 2023 19:07:42 GMT -5
Buy a new replacement carb. Or that lol
Naraku
Nov 30, 2023 13:44:45 GMT -5
Post by FrankenMech on Nov 30, 2023 13:44:45 GMT -5
They are so cheap it is not worth messing with damaged ones.
pili
Post by pili on Nov 30, 2023 17:13:40 GMT -5
True but I like the satisfaction of fixing things. The problem seems pretty obvious that the enrichment is the problem.
