Post by milly on Dec 31, 2023 15:55:13 GMT -5
Well lucky me for a change found the broken bit so will weld that tomorrow 😊
Post by aeroxbud on Dec 31, 2023 17:41:53 GMT -5
Oh no. I know how good your welding is. 🙊🙈
Post by milly on Jan 2, 2024 5:17:10 GMT -5
Post by oldgeek on Jan 2, 2024 5:36:24 GMT -5
milly Last picture, looks like the kickstart gear does not mesh properly with the gear on the crank?
Post by milly on Jan 2, 2024 7:44:26 GMT -5
milly Last picture, looks like the kickstart gear does not mesh properly with the gear on the crank? Correct oldgeek , it's sprung loaded to the casing and raises when the kickstart is used, rises and meshes with the crank teeth and spring pressure drops it back below the teeth again.
Post by milly on Jan 2, 2024 12:41:02 GMT -5
Ground down to fit. Notice the precision screw holding the cutting tool in. Got old Welsh ingenuity or your side of the pond redneck engineering.
sinfull
Post by sinfull on Jan 2, 2024 23:56:42 GMT -5
Milly playing with the 2 strokes 👍
Post by milly on Jan 3, 2024 5:12:35 GMT -5
Milly playing with the 2 strokes 👍 No, no I shall convert it to 4 stroke, can't be having a spawn of Satan machine loose on the road heaven forbid! 😱
Post by milly on Jan 3, 2024 6:59:23 GMT -5
Post by milly on Jan 4, 2024 11:24:35 GMT -5
Slowly coming along nicely.
thatmint240
Popping up the 2 stroke
Post by thatmint240 on Jan 4, 2024 19:06:14 GMT -5
Cant wait to see a video of it running, read the whole thread the other day and came back to see your update. it looks rad! Any plans for an aftermarket exhaust?
Post by milly on Jan 5, 2024 3:49:44 GMT -5
Not seen any for sale and not sure what other models would fit thatmint240
Post by aeroxbud on Jan 5, 2024 4:49:39 GMT -5
Plenty of standard type exhausts for sale still. But couldn't find anything performance wise. The melody was called the aero in the States. Might have more luck searching for some parts using that name.
Post by milly on Jan 5, 2024 6:51:10 GMT -5
Thank you I was trying to think what they called it Stateside aeroxbud.
sinfull
Post by sinfull on Jan 5, 2024 16:03:41 GMT -5
Looks amazing 👏
Great work so far, still insanely jealous of the scooter availability in the UK. You guys really do get the best stuff.
