Post by milly on Jan 6, 2024 10:14:11 GMT -5
Post by aeroxbud on Jan 6, 2024 11:36:57 GMT -5
It's nearly a rolling chassis again. 👍
Post by milly on Jan 9, 2024 7:34:58 GMT -5
At last after much back and forth to the parts shop a belt that fits. Next job tonight when wife in bed is rewire the new ignition switch indoors as cold in the shed
Post by milly on Jan 9, 2024 18:00:55 GMT -5
Wife asleep and ignition switch lead has been extended with a new connector and pins.
Post by monsterunderyourbed on Jan 10, 2024 10:56:16 GMT -5
Damn, that engines guts look like that 02 Vino i just cracked open which is now donating it's bodywork to another frankenbuild en progresse
Post by milly on Jan 14, 2024 6:36:41 GMT -5
No scooter was hurt putting the engine in today. I only use specialized tools.
Post by aeroxbud on Jan 14, 2024 8:37:17 GMT -5
No scooter was hurt putting the engine in today. I only use specialized tools. I have a top tip for you. Every tool is a hammer, unless it's a screwdriver. 😉
sinfull
Post by sinfull on Jan 15, 2024 1:38:41 GMT -5
Best way to install the front engine bolt, whack it with the engine bolt installation tool, a.k.a. big @ss hammer 😀
Put a part number on your hammer and write it in the service manual under engine bolt installation tool 😀
Post by milly on Jan 23, 2024 19:16:58 GMT -5
Was going put on wiring harness today but couldn't find a few bits so put on carb instead then back out the cold shed for the warmth.
Post by milly on Feb 29, 2024 12:33:50 GMT -5
Finally found a bracket that secures battery and oil tank. Bit like finding hen's teeth. Been held up awaiting one of these.
Post by hippo008 on Mar 4, 2024 14:07:13 GMT -5
Unusual little scooter. Whats the engine code on the gearbox cover?
If it uses an AF05 engine there are aftermarket parts available in Japan and some half-decent China clone stuff. I really like the Honda platforms. The early vertical motors arent nearly as efficient as the Minarelli or Morini stuff but they are very reliable and solid if put together properly.
Of course you could always do an AF16/AF18 or AF35 swap for more parts availability too. Tons of aftermarket brackets and instructions on doing those builds too.
Post by milly on Mar 5, 2024 4:09:24 GMT -5
Thanks hippo008 I will check the engine code later.
Post by milly on Mar 17, 2024 18:27:41 GMT -5
Thanks hippo008 I will check the engine code later. It's a A07 engine code.
Post by milly on Mar 17, 2024 18:32:44 GMT -5
So had a little bit of time to spare on it late afternoon, cleaned intake manifold as found some dried mud in it, started on wiring after re routing the stator wire's to the correct side. Have worked out most connections via Haynes manual. One thing never seen before is a blue earth wire.
Post by hippo008 on Mar 24, 2024 12:13:11 GMT -5
Thanks hippo008 I will check the engine code later. It's a A07 engine code. I think that may take AF05 parts. There are all kinds of top ends and cranks available for those, could be worth a look. I’ve not seen an AF07 stamped motor in person before but it looks like the common AF05.
