Post by 09zufar on Mar 15, 2024 9:56:01 GMT -5
Hello everyone.
I currently have a New Way Grido chinese scooter and i was wondering if it's possible to make it more powerful for long distance rides by keeping it a 49cc.
I've been riding for 4 months now and there are situations where i feel unsafe due to the lack of climbing power.
DETAILED SPECS :
Make & Model : New Way Grido Engine : LJ1PE40QMB 2T 49cc Top Speed (GPS VERIFIED) : 72 KM/H Uphill Speed : 40-45 KM/H
My goal is to cruise at around 80 KM/H without any difficulties with a good amount of torque to keep it constant and a little more power in reserve if i want to overtake.
I was going to buy a 19mm super flow carburetor tommorow then i thought i should ask you guys first.
How important is a hi-speed variator in achieving the mentioned speed ?. Is my stock variator not enough if given the right amount of power from the engine?.
thatmint240
Popping up the 2 stroke
Post by thatmint240 on Mar 15, 2024 11:34:14 GMT -5
I would upgrade your CVT first before anything, and if you still need more I would do an exhaust and upjet the stock carb.
Post by 09zufar on Mar 15, 2024 12:33:23 GMT -5
Okay.
I will buy the Malossi Multivar as it is the only model they have here.
and for the upjet, i need to increase only the main jet size?
I'll do these 2 things and maybe post a top speed/acceleration video.
Post by aeroxbud on Mar 15, 2024 15:59:37 GMT -5
The biggest gain for least amount of money is a big bore kit. You could still use your stock exhaust and carb if you wanted. Just change the jetting. I'm guessing at 72kmh if that's on a level road. Your exhaust is not restricted. I variator will help with keeping the revs more constant. And hill climbing. But won't add much to the top speed. An exhaust is the easy option for more power. A good exhaust will give a big increase in top end power.
pili
Post by pili on Mar 15, 2024 20:36:38 GMT -5
I agree with Aeroxbud bang for buck a bbk is your best bet. Jets are cheap and if the needle on the carb is adjustable it’s a little more fuel at partial throttle. It’ll give you a little more top speed and get up to speed much faster which in my opinion is more important for commuting. If you need a few more MPH, a good exhaust like a Malossi Wild Lion will get you in the 80 kph range depending on what the final drive ratio on your scoot is.
Post by 09zufar on Mar 15, 2024 23:25:55 GMT -5
Thanks everyone. Where i live in Mauritius, 50cc's don't come with restrictions.
I will get a 70cc kit, new variator and if possible a new carb or upjet my stock one.
I will post the acceleration video after im done with it.
Post by 09zufar on Apr 1, 2024 4:16:24 GMT -5
Quick Update.
I ordered bigger main jets, high speed variator, and cold air intake.
Already received the jets. Waiting for the other parts.
I wanted to keep it a 50cc. Will update once i install these and do a top speed test.
If it still won't go 80km/h easily then ill go for the 70cc bbk.
