bacon
Scoot Junior
Post by bacon on Apr 21, 2024 19:15:43 GMT -5
bacon
Scoot Junior
Post by bacon on Apr 21, 2024 19:36:05 GMT -5
The pilot jet was in a Yamaha package and was supposedly a NOS 46 pilot
Post by Zino on Apr 22, 2024 0:15:46 GMT -5
yes those mikuni main jets work in stock Zuma carb I have used them
The pilot jet does not look like the one I used
Post by Lucass2T on Apr 22, 2024 4:28:00 GMT -5
TK carbs also take the 6mm dellorto jets. I had a TK 14mm on my axis and had a bunch of Dellorto 6mm's. Works perfectly.
bacon
Scoot Junior
Post by bacon on Apr 22, 2024 7:51:33 GMT -5
This was the package that the pilot jet came in. Is this not the right one? Seems like the head being so much taller might cause issues. On a related note, how many turns do you set your idle air screw at? Mine was still covered with the aluminum disc and I just removed it.
Post by Zino on Apr 22, 2024 7:59:12 GMT -5
1 1/2 to 2 turns out is where you should start with an air mixture screw .
I checked my Zuma build threads that is the right part number for the vino pilot jet that I used in stock carbs try it
Post by bigmatthew86 on Apr 22, 2024 10:56:04 GMT -5
You can also get a 82 & 84 jet from Yamaha. I did the 84 on top performance kit & Leo Zx pipe.
