myers
Scoot Newb
Post by myers on Apr 22, 2024 7:54:09 GMT -5
Hello. My name is Martins, 31 years old from Latvia. Decaded to share my scoot with you. This is a yamaha BWS 1991y, bought it last year in the middle of June. 1st day photo. It had malossi sport 70cc cylinder, malossi rhq crankshaft, stage6 pro replica exhaust, 19mm china carb, malossi e13 air filter and malossi multivar variator, stage6 mk2 clutch. Everything else in the engine was stock. First drive and I was very surprised that for 70cc it was so slow, it maxed out at 55km/h at wot, but acceleration was not so bad. After that, i put on front fork from yamaha aerox and wheels from sr50 2gen aprilia for better looks "my opinion" =] + converted drum to disc brakes. Wanted it a little bit faster so for a good deal I got mxs racing 70cc cylinder. After that it was different story, perfect power for daily driving and riding on rear wheel Max speed with draggy was 90km/h and 1/8 it could do in 11.25sec not bad. After that i drove all season and enyoyomg it. Then winter came and I decided to upgrade the engine more. So I found for a good deal minarelli horizontal engine cases + 2fast crank + 2fast 100cc cylinder for a good deal and could not miss that. After that bought r/t 100cc exhaust, r/t inner rotor ignition, PWK 34mm carb, malossi LA furia overrange set and put all that together. I dont have a lot of pics on that process because i was documenting all that progress in my youtube channel so it is wat it is. custom intake manifold 1st test, without overrange transmision. More vids, racing i3 Testing grip to race 650cc bike Race And some POV driving , still stock gearing, need upgrade to longer ones.
Post by aeroxbud on Apr 22, 2024 10:55:47 GMT -5
That's really nice. Good job. Those wheels look good on there. Something different to the usual Aerox wheel conversion. We're they a simple swap?
myers
Scoot Newb
Post by myers on Apr 22, 2024 12:03:24 GMT -5
That's really nice. Good job. Those wheels look good on there. Something different to the usual Aerox wheel conversion. We're they a simple swap? Yes, they are straight swap on minarelli horizontal engine and aerox fork.
Post by pete130 on Apr 22, 2024 21:30:49 GMT -5
Nice build, the 100cc 2fast will be a different animal. Once you go into the ultra race, set up your around or over 30hp, if you looking for a good intake have a look at the lmr intake 35-40mm, im building something similar in a sr factory, here a photo of the lmr intake, the 35mm just has a insert.
myers
Scoot Newb
Post by myers on May 4, 2024 2:26:25 GMT -5
Nice build, the 100cc 2fast will be a different animal. Once you go into the ultra race, set up your around or over 30hp, if you looking for a good intake have a look at the lmr intake 35-40mm, im building something similar in a sr factory, here a photo of the lmr intake, the 35mm just has a insert. I think LMR make those intakes just for piaggio engines vs 450cc Anyways need more carb tuning, running too rich @ wot
