Post by morphex on Apr 27, 2024 6:05:39 GMT -5
Hi fellow scoots.
What's an easy and effective way to clean the spring that pulls back the kickstarter?
Post by aeroxbud on Apr 27, 2024 6:49:35 GMT -5
I've always found brake cleaner works well.
Post by morphex on Apr 27, 2024 12:05:55 GMT -5
Yeah I thought about that.
What about some solvent I can soak it in?
thatmint240
Popping up the 2 stroke
Post by thatmint240 on Apr 27, 2024 12:26:46 GMT -5
I usually brake clean the area, spray down with some sort of anti oil soap (such as dawn) then power wash the area. You will ABSOLUTELY NEED to regrease everything after you clean it otherwise it will nto only rust instantly but not work properly.
log
Scoot Junior
Post by log on Apr 30, 2024 10:24:57 GMT -5
standard gasoline/petrol is a decent solvent
