Post by Fox on Nov 11, 2012 20:47:42 GMT -5
Post by 90GTVert on Nov 11, 2012 21:00:29 GMT -5
You can get a 3 stone hone from an auto parts store really cheap. I don't like those much for 2Ts though, because they can be hard to use with the ports. I like flex hones, but that'll prob be around $30. Not sure how much it would cost for a shop to do it.
Post by Fox on Nov 11, 2012 21:13:35 GMT -5
Okay thanks.I had a three stone one before but it got chipped up and bent so I chucked it. I'll Google "Flex Hone" and see what sort of deals are out there and call around to see what the rates are for a hone job at a shop. So I got a cheap Sprint smart phone a couple months ago and it takes way better pictures than my old camera. It's more time consuming e-mailing them to myself than uploading directly to my PC from the old camera but at least they aren't blurry anymore.
Post by 90GTVert on Nov 11, 2012 21:17:33 GMT -5
Pics all look very good.
Post by jmkjr72 on Nov 11, 2012 21:23:18 GMT -5
i have a small master cyl hone that i replaced the stones with longer stones wokrs great on the small 2 stroke bores
Post by Fox on Nov 23, 2012 12:50:12 GMT -5
So I went ahead and just installed the cylinder the way it is with the newer piston and new bearing and WOW! It's running like brand new again. Absolutely no hesitation at all on take-off, strong acceleration and 45-48 MPH top speed.
Hope it lasts for a while. :fingers crossed:
Post by aeroxbud on Nov 24, 2012 13:44:25 GMT -5
Good you have the performance back
Post by andrewjones1992 on May 13, 2013 14:46:16 GMT -5
Hey, I am interested in the rear wheel on your TNG venice. I have been looking for a rear wheel for a while now and keep finding so called "TNG Venice wheels," but when they arrive at my house the splines are too small and it will not fit on the axel of my 2008 Venice. Do you know anything about the TNG wheels and if they just aren't standard or if I have been getting screwed?
Thanks, Andrew
Post by ryan on May 13, 2013 16:19:03 GMT -5
andrew i have rear tng venice wheel i give you my word its for it message me
Post by ewasleske on May 14, 2013 17:18:26 GMT -5
I would take the side stand and possibly the center stand (and hardware) if it works for a Vento Triton. Let me know. Thanks!
Post by ryan on May 14, 2013 17:22:58 GMT -5
its for short case so it would be really really short ewasleske
Post by 90GTVert on May 14, 2013 21:11:33 GMT -5
Yeah, the side stand is a different mount and length IIRC and the centerstand is definitely smaller on the short case. It would bolt on, but it may not touch the ground or at least not lift the tire.
liftit
Post by liftit on Aug 9, 2013 13:28:33 GMT -5
Hey, if you still have the body plastics, I could use some. I just picked up a venice missing the rear center piece and the splash guard. Also missing the front piece that holds the headlight. And the headlight.
Post by rockystar on Aug 13, 2013 19:56:08 GMT -5
If u still have this stuff o could really use the oil tank..thanks
mojo
Scoot Newb
Post by mojo on Aug 26, 2013 14:47:47 GMT -5
Do you have any of the green body parts left? I need the front right panel and the cover that goes under the seat. And the wind shield if you still have it. if not, does anyone have a good source for tng venice 49cc body parts?
