Post by fullcollapse on Jul 12, 2013 10:23:02 GMT -5
why does the upper piston ring of my SYM dd50 is always broken. i bet it's not lean because i set it to nearly rich and the plug reading is near to rich. it had just broke 3 rings. please help me. thanks in advance
Post by ryan on Jul 12, 2013 14:06:06 GMT -5
pictur please and look in your sleeve for abnormal wear or scuffs maybe its hanging up on a port or maybe your getting wrong rings. maybe its a 39mm piston or 40mm piston either way mixing the rings up will result in thus
Post by stepthrutuner on Jul 12, 2013 14:07:05 GMT -5
What is the situation with your cylinder? New? Used?
Post by Corrosion on Jul 12, 2013 15:46:28 GMT -5
Are you checking, End-Gap.
Post by 808twosmoker on Jul 12, 2013 16:03:15 GMT -5
pictur please and look in your sleeve for abnormal wear or scuffs maybe its hanging up on a port or maybe your getting wrong rings. maybe its a 39mm piston or 40mm piston either way mixing the rings up will result in thus Agree, check to make sure your piston/cylinder is apples to apples, look for wear inside it (unusual gashes etc) if its just the top ring I would think there may be a clearance issue. take the head off and move the crank by hand until your piston top comes to the end of the cylinder
