Post by sai on Sept 11, 2013 19:59:11 GMT -5
So i read on many places that this exhaust is prone to rusting, it's started to rain for a week here and I thought... since the exhaust is still new and good, how do I prevent it from rusting?
Some people said ceramic coating?
Any advice?
Post by sai on Sept 11, 2013 20:47:40 GMT -5
Post by moofus02 on Sept 12, 2013 3:28:21 GMT -5
I've had my zx 5 years never done a thing to it. It's got a rust bluing appearance on the head pipe and front cone but it's not nasty looking by any means
Post by 90GTVert on Sept 12, 2013 9:20:43 GMT -5
Easiest way would prob be a high temp paint.
I've always thought a Jet Hot ceramic coated pipe would be cool, but it's expensive. I had them do my headers, crossover pipe, and downpipe for my car and it was about $500 for their Sterling coating. It's not chrome/mirror by any means but a shiny silver more like a mild polished aluminum. Guessing $100-200 range for them to do a scoot exhaust.
Post by sai on Sept 12, 2013 9:25:44 GMT -5
THat's expensive.
I guess I'll just do what Ryan does, which is WD40 wipe on a rag every so often
Post by jmkjr72 on Sept 12, 2013 16:59:42 GMT -5
Strip all the crappy clear coat off it Then prime with with vht flame proof primer and paint with vht paint Cure it witn a propane torch
Post by forde88 on Sept 12, 2013 20:19:32 GMT -5
Barbecue paint.
Post by stepthrutuner on Sept 12, 2013 20:23:24 GMT -5
What is it that John, 190Mech, swears by? GloCoat floor finish applied periodically from new?
Post by 90GTVert on Sept 12, 2013 21:51:11 GMT -5
Mop N Glo
Post by sai on Sept 12, 2013 23:57:54 GMT -5
One of th mechanics told me mop n glo mix in water, spray to the areA then do it so I get 4 layers. I should try that huh?
Post by 90GTVert on Sept 13, 2013 5:33:55 GMT -5
I think John just wipes on a few coats.
Post by sai on Sept 13, 2013 10:38:28 GMT -5
without mixing it with water? Just spray and wipe a couple of times?
Post by 90GTVert on Sept 13, 2013 12:02:51 GMT -5
For pipe cleaning,I use "Naval Jelly"(phosphoric acid) and a scotchbrite pad,rinse in hot water and dry,warm up pipe,then apply 3 coats of 'Mop-N-Glo' floor polish(yep you read that right!).Works Great!!
Post by sai on Sept 13, 2013 14:00:31 GMT -5
THank you, Brent.
