Post by nelson on Mar 1, 2014 23:01:42 GMT -5
Part 2 I made the 4 hour trip, should be picking up new jog in the morning! Can't wait hope it isn't a dissapointment
Post by moofus02 on Mar 1, 2014 23:23:51 GMT -5
Glad you made it best of luck hope it's everything you want and more.
Post by nelson on Mar 2, 2014 19:49:15 GMT -5
Wasnt ideal driving conditions. Took 6 hours to get home in this. Bad weather came sooner than expected.
Post by nelson on Mar 2, 2014 19:50:33 GMT -5
The bird is in the nest
Post by nelson on Mar 2, 2014 19:58:59 GMT -5
Came with this carb. Guy said he was trying to get the bike running. The end of the crank is snapped off where someone waay over tighten it. So needs new crank.he did say it had a bbk already in it.doesn't matter as I am putting the 90 in it. Sweet carb!
Post by nelson on Mar 2, 2014 22:05:43 GMT -5
The bike came from Hawaii. Still has Hawaii plate/tag. And some daytona old performance parts
Post by usmcdoc on Mar 3, 2014 7:41:04 GMT -5
Came with this carb. Guy said he was trying to get the bike running. The end of the crank is snapped off where someone waay over tighten it. So needs new crank.he did say it had a bbk already in it.doesn't matter as I am putting the 90 in it. Sweet carb! That SUDCO Carb is a Mikuni product. It's a Flatside Carb so it is not stock..you got a freebie performance Carb even..
Post by nelson on Mar 3, 2014 11:35:54 GMT -5
YeA they are well sought after in the mx and atv world. Should work just fine with my 90 :-)
Post by nelson on Mar 3, 2014 16:39:39 GMT -5
Post by nelson on Mar 3, 2014 16:41:22 GMT -5
Out with the old IMG]http://i57.tinypic.com/280sakg.jpg[/IMG]
Post by nelson on Mar 3, 2014 16:42:00 GMT -5
Post by nelson on Mar 4, 2014 18:13:28 GMT -5
So I bought the 90cc cylinder fan shroud is the side cover the same as the 50? Or I need to buy that also? I think the side cover is interchangeable?
Post by 90GTVert on Mar 4, 2014 19:05:00 GMT -5
Side cover should work.
Post by birdman on Mar 5, 2014 0:30:49 GMT -5
Sweeeet scoot!!
Post by nelson on Mar 5, 2014 8:57:55 GMT -5
new scoot came with this intake. i guess i will be using it with the carb that acme with it. The rubber that connects the carb and intake is dry rotted. I will have to make a new one out of some rubber. Does anyone have any experience with this intake? Since i dont have a stck one this will suffice i auppose.
