Post by buddyearl on Apr 10, 2014 16:14:07 GMT -5
I have a 50cc Propel scooter that won't start after warm. It's getting good gas flow and spark. I've adjusted both valves to .002. Any help is appreciated.
Post by 90GTVert on Apr 11, 2014 10:59:53 GMT -5
You covered the first thing I thought.
Does the plug foul? Maybe it's running rich and if the enricher kicks in it's a little much for it. Try holding it wide open next time it's warm and see if it fires up.
If you have a performance CDI try swapping it out and see if it continues.
Any other symptoms? Hard cranking? Poor running once it's going?
Post by 2TDave on Apr 11, 2014 13:33:30 GMT -5
Isn't .002 a little tight seeing as it's going to get tighter when warm?
Post by 90GTVert on Apr 11, 2014 14:12:22 GMT -5
The service manuals call for just under 0.002" sometimes. It should be fine at 0.002". Could try 0.003" and see if anything changes if nothing else is working.
