Post by TruseiC on May 28, 2014 13:08:55 GMT -5
Hello, today was about to get my dremel and do some cylinder modifications done, but, got a question, how much can i raise my exhaust port? Had the formula for that, but i kinda lost it Does anyone have it?
Post by 190mech on May 28, 2014 14:14:41 GMT -5
Oh My!!Simple question,1000 answers!!!I will ask some questions now,what brand,type,size of engine?What is the bore and stroke?What do you plan to use it for?Do you plan to make other mods also??
Post by TruseiC on May 28, 2014 14:27:31 GMT -5
Honda af18, air cooled, vertical cylinder engine. 39mm bore 40mm stroke stunt purpose only. Will do some cvt tuning.
Post by 190mech on May 28, 2014 20:07:29 GMT -5
Stunt work will need a torquey build.That would not require much work.Checking your current port timing with a degree wheel will give us all some real numbers to think about; 49ccscoot.proboards.com/thread/353/port-durations-degree-wheel-methodsYou can likely get your desired torque with some mild port and head work,or a 70cc kit would be a better/cheaper solution..
Post by 2strokd on May 29, 2014 10:34:29 GMT -5
I think Polini offers the iron Sport kit for that engine. If so and its in your budget this kit will provide plenty of stunt toque. I have owned a couple of those kits with great results!
Post by TruseiC on May 29, 2014 11:09:08 GMT -5
Well, for now i have very limited budget, gotta wait till July for some real $$$ so now im trying to squeze out the max, what this engine can give with stock parts
Post by vlatx on Jun 8, 2014 18:55:35 GMT -5
You can grinde of the exaust port by 2mm up ,and 2mm sideways.and get a comresion ratio at 11:1 for more torque.
Post by TruseiC on Jun 9, 2014 2:52:25 GMT -5
2mm to both sides, or 2mm to one side, and then 2mm to other?
Post by vlatx on Jun 9, 2014 6:00:23 GMT -5
