Post by 2TDave on Jul 13, 2014 6:00:54 GMT -5
How do the splines on the crank look? It should not wobble when tightened.
t2no
Post by t2no on Jul 13, 2014 6:22:55 GMT -5
Splines are visible in a pic in previous posts. Actually they look a bit worn out. But the ships should go on the out side of the fan plate on top of the locking star? Or on top of boss drive? And also on fan wheel there is a recess in the middle isn't it for the boss drive to go in a bit?
Post by 2TDave on Jul 13, 2014 6:38:03 GMT -5
There is normally one washer the same diameter between the boss and fan pulley that fits in the recess. It can be removed for a higher top speed(at the cost of a slower take off) but it would have to be put on the other side between the star washer and kick start cog. This has been the case on the minarelli 2t CVTs I've worked on. Not sure about others. The low rpm noise was likely the rollers you were hearing.
t2no
Post by t2no on Jul 13, 2014 6:48:37 GMT -5
OK, Thanks, need to sort this out.
t2no
Post by t2no on Jul 13, 2014 14:25:08 GMT -5
So did this thing with a washer, top speed 68 km/h happy happy Now just need to sort out carb adjustment and it will sweet bike thanks guys one thing, when accelerating in the beginning I can feel the belt vibrate, is that normal? or I did something here?
Post by chehystpewpur on Jul 14, 2014 7:32:58 GMT -5
So did this thing with a washer, top speed 68 km/h happy happy Now just need to sort out carb adjustment and it will sweet bike thanks guys one thing, when accelerating in the beginning I can feel the belt vibrate, is that normal? or I did something here? I can feel my belt wobble sometimes on takeoff too. Its just the variator and clutch trying to grab and the extra slack at the bottom being created. I'm glad to hear your getting it sorted out its about time. One thing I do to get my carb adjusted really good is put in heavy ass weights and whatever settings accelerates best is usually the one I go with unless its a hair lean. Then I put the ones I plan on using back in.
t2no
Post by t2no on Jul 14, 2014 17:28:03 GMT -5
I think my carb still needs to be adjusted, but its nice that it drives so much better now
ivri
Scoot Junior
Post by ivri on Jun 28, 2021 0:58:06 GMT -5
great thread. I'm going thru same issues. 50cc 2000 piaggio thyphoon dellorto 17.5 hpva leo vince evo 2 previous owner premix. so i removed oil tank would love to know if you got in tuned like it should and do you still own the bike.
