Post by eltatertoto on Jul 6, 2014 0:52:44 GMT -5
hello all. today my friend richard called me. he said his scooter wheel was falling off over 50 miles from home. he pushed it to a shop, and they jury rigged it with this nut setup. my scoot dont have the second strut the axle goes thru, so i dont know what bearing was originally there or if its even bolted together correctly. seems like that giant nut they put there could just spin right off. ( i assume its a design flaw, which is why the original one came off. lol) any help in sourcing the correct parts is greatly appreciated. and local part#'s would be phenominal. EG. yamaha honda etc. thanks alot guys!
Post by craisin on Jul 6, 2014 3:26:57 GMT -5
What Brand scooter is it?
Post by scooterpimp on Jul 6, 2014 11:05:33 GMT -5
Anything left of bearing to get a # from it? Or measure id& od & width to match up somewhere.? Gotta keep an eye on bolts etc. Time to time for looseness. Loctite is a scooterists friend. Check with scrappy or scoot places for a replacement? Make sure that shaft isn't all bogarted up too.
Post by stevec on Jul 6, 2014 19:44:03 GMT -5
scrappy dog has swing arms for long and short cases for around $35
rexxk
Post by rexxk on Jul 6, 2014 22:51:00 GMT -5
answer to video, a new one.
Post by eltatertoto on Jul 7, 2014 1:01:20 GMT -5
no bearing left... old one is on the road somewhere. i assume there is supposed to be a bearing, then a washer then a nut. i need to know what bearing to get, preferably with a part#.... scooter is a TAOTAO 50.
thanks again guys. glad im not the only one sortof stumped. lol
Post by stevec on Jul 7, 2014 5:09:26 GMT -5
the swing arms i have seen have 2 bearings pressed together, mostly the VIPs have bearing issues that i have worked on.
Post by 90GTVert on Jul 7, 2014 5:35:37 GMT -5
I see two 6203Z bearings mentioned for a swingarm. Not sure if that's correct, but you can check to see if it should work. The 6203Z should be 17x40x12 so you can see if the swingarm is 40mm ID and could take two 12mm thick bearings and also if the axle is basically 17mm.
Post by eltatertoto on Jul 7, 2014 11:11:33 GMT -5
i could not find the swing arm anywhere on the site..... i will have him measure the shaft and swingarm. thanks alot!
Post by scooterpimp on Jul 7, 2014 18:45:15 GMT -5
Make sure outer races are out before measuring (if they didnt fall out also).
Post by stevec on Jul 7, 2014 20:00:15 GMT -5
swing arm is under common parts on scrappy dog.
Post by eltatertoto on Jul 8, 2014 1:08:33 GMT -5
Post by craisin on Jul 8, 2014 5:22:54 GMT -5
Post by stevec on Jul 16, 2014 19:01:45 GMT -5
scrappy dog under GY6 150cc 157QMJ parts if it is a 150, he doesn't carry 50cc swing arms. i thought it was under common parts, my mistake.
Post by stevec on Jul 16, 2014 19:03:19 GMT -5
you may have to use a file or emery on the shaft where the swing arm goes on, it gets rough at the end where it won't slide over, you will know if it is very hard to get the swing arm off.
