Post by honda4stroke on Jul 19, 2014 23:13:00 GMT -5
Ok, so, whenever I accelerate from a stop sometimes I hear a little squeak whenever the engine rears up. It sounds like a cherp from a cricket. I think it has something to do with the moving parts in the cvt that are making it shift. What do you guys think it might be?
Post by Upgrayedd on Jul 19, 2014 23:47:25 GMT -5
have you serviced your transmission yet?
Post by stevec on Jul 20, 2014 10:42:26 GMT -5
check your belt for wear, it may have worn where it is not as wide. that will cause it to slip before it grips the variator. like upgrayed says, make sure you service the transmission, put in some new gear oil. you should also check the rollers for flat spots.
Post by honda4stroke on Jul 20, 2014 11:48:22 GMT -5
Ya I've changed the gear/transmition oil a couple thousand miles ago. They said the belt looked fine then, it's got 5000 miles on it so it's probably time for a new belt
Post by Upgrayedd on Jul 20, 2014 12:37:25 GMT -5
Ya I've changed the gear/transmition oil a couple thousand miles ago. They said the belt looked fine then, it's got 5000 miles on it so it's probably time for a new belt transmission is dry. gear oil goes in your final drive. what i meant by asking if you had serviced your transmission is, have you removed your cvt cover, and inspected it, and cleaned out the belt dust, road debris, oil, oil mixed with belt dust, cleaned off pulleys, cleaned variator, etc?)
Post by honda4stroke on Jul 20, 2014 16:47:42 GMT -5
No I haven't done that. But I can tell there's a lot of dirt in there because I was trying to remove the belt cover today and when if got my hand under the cvt cover I could feel a lot of rubbery dust. Maybe from cvt belt? I was unable to remove the whole cover, because it was really hard to pry off and I didn't want to force it.
Post by 2TDave on Jul 20, 2014 17:10:22 GMT -5
Make sure you have all the bolts out. A lot of covers have a bolt in the center that can be hidden behind the kick start lever. A good tap with a rubber mallet should free it up once all the bolts are out.
Post by jeffwah on Jul 24, 2014 15:21:10 GMT -5
A few weeks ago, I had a similar "chirping/cricket " sound you described on acceleration. I messed around with a lot of different stuff (including strategic greasing, oiling, etc.) but my ultimate fix was to deglaze the clutch pads. I used an electric sander with 200+ grit sandpaper. I thought I'd post the tip because no one had suggested it yet.
