Post by vesurka on Aug 3, 2014 21:34:12 GMT -5
I just installed a big valve head with new gaskets but i want to check for oil leaks and i hate having to take the shroud off and on to keep checking. will it be okay if i take it out for like a 1-2 mile ride without the shroud just to check for leaks? or will the heat cause harm in that short of a ride? thanks.
Post by scooterpimp on Aug 4, 2014 4:19:00 GMT -5
Not recomended , the covers are for cooling.
Post by stevec on Aug 4, 2014 5:01:37 GMT -5
the oil will leak past the shroud, you will see it. i wouldn't run it without one.
Post by vesurka on Aug 4, 2014 22:10:47 GMT -5
I ran it for about a half mile at WOT once it was warmed up, no leaks and no sign of damage. shroud is now back on.
nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on Aug 4, 2014 22:35:32 GMT -5
That was taking a chance but glad you did not burn it up, you do a compression check before the run and after to see if it's the same
Post by rocketdog on Aug 5, 2014 18:39:04 GMT -5
I ran it for about a half mile at WOT once it was warmed up, no leaks and no sign of damage. shroud is now back on. Short time periods with air blowing over the engine never hurt any of mine. Don't sit in traffic or let it idle for extended periods of time. It'll be fine. I see you already did it.
