jps
Scoot Junior
Post by jps on Aug 26, 2014 22:36:09 GMT -5
I would like to ask. my problem is,If i have no load on my scooter the clutch engages,when there is weight barely moves. please help what could be the cost? I was thinking clutch pads?
Post by 2TDave on Aug 27, 2014 5:31:07 GMT -5
The clutch springs are probably worn or I've seen the holes in the shoes the springs go into become elongated. If the holes are not round you'd need a new clutch if the holes are round and not elongated then new springs should do it.
jps
Scoot Junior
Post by jps on Aug 28, 2014 4:05:05 GMT -5
The clutch springs are probably worn or I've seen the holes in the shoes the springs go into become elongated. If the holes are not round you'd need a new clutch if the holes are round and not elongated then new springs should do it. hi .
jps
Scoot Junior
Post by jps on Aug 28, 2014 4:10:41 GMT -5
hi mr 2t dave these are the photos of my clutch the contra spring is for 125cc the clutch shaft has a deep cut on it,
jps
Scoot Junior
Post by jps on Aug 28, 2014 4:18:44 GMT -5
Post by 2TDave on Aug 28, 2014 5:11:20 GMT -5
That contra spring may be too stiff depending on your motor. Is it a stock cylinder and exhaust? I can't tell what deep cut your talking about. The pulleys should slide freely and the clutch bell should be smooth and not glazed. The older clutches were 2 shoes and the springs should be tight. Hope this helps.
jps
Scoot Junior
Post by jps on Aug 28, 2014 7:16:04 GMT -5
yes sir its all stock,the pulley is sliding freely but i have no way of telling if the groove on the pulley are still good,because it doesn't have a pin to separate. sir is it ok if i change my clutch shoes to a 3 piece one? attached photos are the deep cuts on the pulley shaft. is this ok? no worries on this?
Post by 2TDave on Aug 28, 2014 8:40:08 GMT -5
Looks like the contra spring has been digging in it. I'd put a stock contra in and replace that base. It may take some work but it will slide up and off. You can put a three shoe clutch on just make sure to get one with the same diameter as the clutch bells inner diameter or order a new bell that matches.
jps
Scoot Junior
Post by jps on Aug 28, 2014 21:09:44 GMT -5
oh...I see..sorry for the million questions and I thank you for helping me. I'm new at this,I had a scooter before but not this many problems. I actually got my scooter very cheap but not running,I had to re bore it then finding out there's more problem so....here I am lol!.
Post by 2TDave on Aug 29, 2014 5:36:40 GMT -5
No need to apologize. This forum is all about learning and sharing. You'll find a solution to your problem and then you'll be able to help the next guy. So ask away!
jps
Scoot Junior
Post by jps on Aug 29, 2014 21:47:04 GMT -5
Thank you so much...I found what my problem was. The contra spring I was using (red one) is to short. It measured 70mm my standard spring should be at least 109mm so this is why my clutch is not engaging enough. again I would like to thank you.
Post by 2TDave on Aug 30, 2014 6:00:34 GMT -5
A lot if the stiffer springs are shorter. There's no need for a red spring on a stock set up. The contra shouldn't have an effect on the clutch engagement though. That's the clutch springs job. Hope you get it sorted out.
