Post by aido21 on Sept 24, 2010 14:18:14 GMT -5
Hi,
New to the forum, have a problem n need a bit a help, have a spy n the revs keep disappearing(sounds like weird misfire), like power dies n then kicks back in, keeps doing this, it seems to be happening more at half n full throttle, could this be an issue with fuel or something more serious? everything is stock on the scooter except leo vince gp exhaust with rollers n clutch springs fitted
Cheers.
Post by 90GTVert on Sept 24, 2010 17:25:40 GMT -5
:welcome:
It could be a fuel issue, but I would suggest checking the ignition system over first. Check all the connections. Spark plug cap, coil, stator, switches, etc... Check the plug out as well. Most fuel problems that I've had don't sound like misfires unless they are way rich and sputtering.
Post by aido21 on Sept 24, 2010 17:47:58 GMT -5
yeah the spark plug connector/cap is quite loose, not clicking onto the top of the plug like it should n more just sitting onto it, also the electric start only works half the time, never straight away takes a few go's, would this point to ignition issue like you suggested?
Cheers
Post by 90GTVert on Sept 24, 2010 18:30:21 GMT -5
The electric start is a completely different system. Replace the cap before you do anymore troubleshooting.
Post by Fox on Sept 24, 2010 20:00:21 GMT -5
Agreed! Gotta be the cap. The cooling fan is probably making the cap come away from the plug at higher RPM's.
Post by aido21 on Sept 25, 2010 9:23:54 GMT -5
Checked the cap n was only sitting half down on the plug had come away a bit so have ordered a replacement, straight forward to fit?
Post by 90GTVert on Sept 25, 2010 11:03:22 GMT -5
Yeah. You unscrew the old cap from the plugwire. if you have enough, it's not a bad idea to cut 1/4" or so off of the end of the plug wire to give the new cap a good seat. The new cap just screws onto the plug wire.
Post by aido21 on Sept 26, 2010 18:47:15 GMT -5
Thanks a lot for that, would you know, im changing my rear pulley assembly at the moment, its an old 105mm setup n I want to convert to 107mm, can I just buy a new 107mm clutch & bell or do I have to change the actual rear pully itself??
Post by 2strokd on Sept 26, 2010 18:50:09 GMT -5
You should be able to get away with just the clutch and bell. Welcome BTW!
Post by aido21 on Sept 26, 2010 19:24:43 GMT -5
cool, was just asking coz seen online sum ppl have had trouble with contra springs fitting when changing from 105 to 107mm, know its only 2mm difference, is the contra mean to turn freely r be tight fit?
Thanks man
Post by aido21 on Sept 26, 2010 20:05:50 GMT -5
sorry, what im trying to get at is, are the inner diameters of the 105 & 107 clutches (where the contra sping sits) the same size? thats what I meant to ask
Post by 2strokd on Sept 27, 2010 2:56:17 GMT -5
I have run all different sizes clutch and bell without a problem with the torque spring fitting....You should be fine.
Post by aido21 on Sept 27, 2010 8:46:14 GMT -5
Thanks man, see how I get on anyway, just going back to the sparkplug cap, when 90GTvert said it simply screws off when changing the cap, I didnt think it would literally be a thread going into bare wire cable insulated tightly in the rubber lead, thought there would be some sort of connector, strange
Post by 90GTVert on Sept 27, 2010 9:09:39 GMT -5
It's a simple setup, but it works pretty well.
Post by aido21 on Sept 27, 2010 9:17:00 GMT -5
yeah it is, got a new 17.5 dellorto carb there to replace the original 12mm, came with a 90 main jet, not sure exactly what im doing, is it difficult or does it just take time? have bleedin loads a stuff going onto it at the moment
