Post by Elektrey on Sept 7, 2014 20:04:33 GMT -5
I had some allen bolts in my CVT case that were impossible to get out with an allen key. I found a nifty solution for something I had and maybe something others have so I thought I would share it. Basically its this IKEA tool It was about $3 at IKEA. I took it, put all the tools inside except the allen key. Rotated the allen key to be perpendicular to the tool. Then I tightened down the screws so none of the tools could move. Tighten very hard. Then, with a good grip on the whole thing I was able to loosen the allen bolts pretty easily. Now They probably sell allen keys with a stronger base with more grip or some other tool more suited for this but if you live near an ikea it may be worth it to pick one of these things up next time your in there. they are pretty cheap and useful for other things.
Post by katastroff on Sept 7, 2014 20:06:15 GMT -5
Nice find!!!
Post by 90GTVert on Sept 8, 2014 9:38:11 GMT -5
Post by Nokatay on Dec 4, 2014 21:08:04 GMT -5
I carry a pencil case with enough tools to take the whole bike apart, including one of those folding allen key sets under the seat.
Post by FrankenMech on Dec 16, 2014 21:48:09 GMT -5
Steel bolts threaded into aluminum can be a nightmare due to corrosion. It may help to strike the fastener a few times with a hammer using a regular hex key held with a pair of pliers or a socket style hex driver.
Always use anti-seize on steel fasteners in aluminum. You can purchase crayon type sticks of anti-seize at some parts stores. They can get kind of messy so some sort of container for them should be made out of tubing.
Post by Elektrey on Dec 16, 2014 21:58:09 GMT -5
Yes, I just removed my intake and the hex bolts were stuck so I put a key in it and hit them with a mallet, freed it up after a little bit.
