Post by katastroff on Sept 8, 2014 5:55:00 GMT -5
I dont know if this was posted before (i was too lazy to search ) but this method could be usefull when on the road.
Also helps if you dont have a 2k contra spring
Post by 90GTVert on Sept 8, 2014 9:47:05 GMT -5
It's a good method for the scoots it works with, but I will say don't plan on not needing any tools if a belt breaks on the road. Sometimes when a belt breaks the rollers will get out of place in the variator and you'd have to take it off to reset them. If the goal is preparedness, carry a variator locking tool of some sort and a ratchet and socket that fit the nut. If you're gong on a longer ride, check your belt before you leave and if it's in questionable condition, replace it.
Post by Fox on Oct 4, 2014 20:33:55 GMT -5
Yeah Brent's right. 9 times out of 10 the rollers will come out of their slots and get jammed up in there from the variator closing farther than it normally would once the belt breaks so you have to remove the variator anyway.
Brent is also right about knowing the condition of your belt. A responsible scooter owner will check/clean out the CVT every so often so they will know if the belt is getting worn out.
Post by Deleted on Oct 8, 2014 12:34:01 GMT -5
if things were only that simple...
Post by dudescoot on Oct 9, 2014 9:40:51 GMT -5
Is there a way of knowing the rollers are out of place?
Post by 90GTVert on Oct 9, 2014 14:25:37 GMT -5
The variator won't open all the way (close against the ramp plate) if they're out of position.
Post by Fox on Oct 9, 2014 18:57:56 GMT -5
This video is better cause of the camera angle and there is no chatter. At no time does he allow the variator pulleys to close up. He even shoves a curved piece of cardboard in there so that there is no chance of the rollers coming out of their slots.
Post by scooterpimp on Oct 10, 2014 10:59:59 GMT -5
Still like to see someone pull in a strong contra by hand. , just cant do it with my old D. Beaters.
Post by craisin on Jan 18, 2015 13:41:44 GMT -5
where he sticks the fingers on his left hand i stick the handle of a 10 inch cresent. I do have the hand strength to do it but its easier.
Post by craisin on Jan 18, 2015 13:57:30 GMT -5
and you have to take the starter clutch out on the scooters use the variator as a ring gear
