taz
Scoot Junior
Post by taz on Sept 23, 2014 20:13:37 GMT -5
I just pick this big chief 50Q2-15 up and am trying to find a carb for it!!!I see a ton on ebay and some other places but i dont know what the hell carb i need and dont even know what engine is in it hard as hell to find info can anyone help??
Post by katastroff on Sept 23, 2014 20:29:52 GMT -5
Hi and welcome!!!!
You can find the engine type here:
But from the look of the model number, I bet ya a penny its a 4t chineese scooter.
Post by 90GTVert on Sept 24, 2014 7:08:10 GMT -5
taz
Scoot Junior
Post by taz on Sept 24, 2014 11:35:39 GMT -5
Thanks for help will check this afternoon thanks alot for quick response!!
Post by Elektrey on Sept 24, 2014 13:10:29 GMT -5
if its 50cc most likely a generic 19mm $20 carb on ebay will work. Probably with an auto choke.
taz
Scoot Junior
Post by taz on Sept 25, 2014 12:39:07 GMT -5
ok with the help of you guys i found engine number here it is and it doesn't have auto choke that's for sure has a thumb choke but even with the engine model i am having trouble! Engine=JL1PE40QMB Any more help would be great !Thanks so much already got me moving here!!
Post by 2TDave on Sept 25, 2014 12:47:30 GMT -5
That's a two stroke minarelli clone number.
Post by niz76 on Sept 25, 2014 14:20:36 GMT -5
U got the good motor!
taz
Scoot Junior
Post by taz on Sept 25, 2014 14:39:37 GMT -5
Thanks this is a great site glad i found im new to scooters but i see i will get and have gotten a ton of help already now to find the right carb for this thing.Starts great and idles fine but the minute i give throttle bogs down but if i hold choke wide open while riding runs great!!So i am assuming this is a carb issue and seems they are so cheap and plentiful on ebay if i could figure out which one is the right one for my scooter LOL, it is easier to buy new then mess around taking apart and cleaning??
Post by katastroff on Sept 25, 2014 14:41:40 GMT -5
Post by 2TDave on Sept 25, 2014 15:29:25 GMT -5
Then it sounds like it's lean. Is the stock airbox hooked up?
Post by Elektrey on Sept 25, 2014 18:00:06 GMT -5
If it idles fine, and WOT is fine, change the needle clip position in the carburetor.
taz
Scoot Junior
Post by taz on Sept 25, 2014 18:55:04 GMT -5
ok well first thing i notice after removing carb there is no hose from carb to air box carb running with no cleaner!!now i need to find this part also i took off carb and cleaned out real good bur no need reinstall until i find carb to air filter tube.is there a good site to find parts for this scoot.
Post by 90GTVert on Sept 25, 2014 19:02:02 GMT -5
Post by Elektrey on Sept 25, 2014 19:08:58 GMT -5
ebay will have a lot of generic cheap chinese parts for your scoot. Just search 1E40QMB with whatever you need and it will most likely fit. that or "minarelli" etc.
