Removing Dents From A Pipe : 2 Methods
Sept 28, 2014 20:44:44 GMT -5
90GTVert and katastroff like this
Post by oldgeek on Sept 28, 2014 20:44:44 GMT -5
First I should mention that while there are dangers using this method to remove dents from a pipe, I think it can be done safely with care and experience, at your own risk, of course!
Also I don't recall who on this forum told me this could be done, but it was here that I heard about it.
I made 2 block off plates for the pipe. 1 of the plates has a fitting for my nitrogen tank. I made gaskets to seal the plates to the pipe from a section of bicycle inner tube.
It was hard to take decent before and after pictures, and they don't really show the damage or repair very well. The damage was pretty bad across welds and seams and flattened on the smaller section of the pipe in 2 places.
I hooked my nitrogen regulator to the fitting on the plate to check the seals for leaks. The seals were good, however there was a 2" split in a weld that I didn't know was there. I decided to try fixing the dents without fixing the weld, but I learned that was a waste of time, it only opened up the split more. I then decided to try and weld the seam up with my ox/acty torch using the only filler rod I had handy, flux core mig wire. I have never done anything but braze copper with a torch, so this was new to me. It went rather well after I got the heat adjusted right, and got the hang of it. I had several pinholes pop up while blowing the dents out that I had to stop and repair. After getting the pipe pretty well sealed up, I started heating up a dented area cherry red with the torch, then I reached down and cranked my nitrogen regulator to about 150lbs watching closely as I continued heating the dent. I could see the dent pushing out, and it was fairly easy to control the temp. The dent only moved when it was really, really hot, the moment you remove the torch it stops moving. I ended up using just over 200lbs of pressure on the nitrogen regulator to push the dent out of the smallest section of the pipe. I would think you would use MUCH LESS pressure on a larger section of the pipe. Overall I am very pleased with the outcome of the repair. Now I need to make/get another silencer tube because the carbon fiber one that came with it is shot.
