Post by spaz12 on Nov 26, 2015 15:52:50 GMT -5
Get an 85. You should get several jets actually.
Post by triesandluth on Nov 26, 2015 16:07:04 GMT -5
Yeah, I've been searching for a decent priced jet kit. Pisses me off that I have four different jet types now. Wish they were less complicated and interchangeable. What's this third jet for on these clones? I've only dealt with the two
Post by spaz12 on Nov 26, 2015 18:22:45 GMT -5
It's the starter jet. Never ever saw anyone that had to change it. It should be a 60.
Post by triesandluth on Nov 26, 2015 18:49:03 GMT -5
You are correct, 60. Is that off of the choke?
Post by spaz12 on Nov 26, 2015 19:00:50 GMT -5
Post by Elektrey on Dec 11, 2015 13:46:31 GMT -5
hey guys sorry I havent updated, it still sitting in my garage. things I have to do: - Get new battery
- Probably new gas
- get solder for squish clearance
- tinker with engine shroud to get the thermocouple to fit through it
- ensure stator is functioning
- ensure temp display gauge is working
- rejet/tune rollers?
thats about it, hopefully it works. oh and one important question I didn't think of before: I have the display gauge hooked up to the AC circuit of the stator/rectifier. Does it care if it gets 12v DC vs. 12v AC?
Post by 190mech on Dec 11, 2015 18:13:10 GMT -5
Needs to see DC or you'll "let the magic smoke out"!!
Post by Elektrey on Dec 11, 2015 19:00:59 GMT -5
ok need to rewire it then
Post by Elektrey on Dec 14, 2015 13:26:06 GMT -5
So gonna do this in two phases
phase I: install new battery drain fuel if needed install new plug measure squish (should be good) start it up, as long as it runs/revs should be done with phase I
then onto phase II: wire up the temp display modify shroud to accept spark plug temp wire tune jetting tune rollers etc.
Also, I'm going to postpone both phases until
a) it gets cooler (it was 85 today!) b) I have some money to work with.
Post by Elektrey on Feb 3, 2016 18:54:29 GMT -5
bought new plug.
Is a squish test mandatory? it only came with one gasket. Am I wrong to assume squish is correctly set from factory? Went by lowes and advance auto parts today to try to find solder. Advance auto parts had 3/32" for $5.99 which was too big I thought and lowes had some a bit smaller probably 1/16" but it was $9.99 and didn't really feel like spending that.
I've rotated the piston using the fan/flywheel and it feels fine/no hitting the head, suction feels fine.
Post by Florida Antique on Feb 3, 2016 19:16:31 GMT -5
You should try Harbor Freight or Radio Shack for solder. If you want to travel a bit, Skycraft in Winter Park probably is the cheapest place around here
Post by niz76 on Feb 3, 2016 20:07:43 GMT -5
I think squish check is quite important on a tuned ride like yours! Can answer a lotta questions... Some folks oil up some modeling clay and squash that.. might b kinda hard to measure accurately though... ;P
Post by 190mech on Feb 3, 2016 20:18:09 GMT -5
We used modeling clay back in the 70's,it worked good,cut with razor and measured thickness,had young eyes then,now I like solder,,squash it, digital caliper it,adjust as needed!!
Post by Elektrey on Feb 3, 2016 20:31:13 GMT -5
alright ill make the effort then, radioshack might not even sell that stuff anymore since they've become best buy 2.0, I wonder if they're even still open haha.
harbor freight shows some online for $3.49 and it looks small so i'll go pickup that
Post by drc174 on Feb 3, 2016 20:59:19 GMT -5
I ran by eye and experience (aöright the thick gasket is for chill use right? Lets add anotjer one, the thin metal one.)
Came to 1.1mm, drove a year
After i messured now, i am down to 0.85, thats as low i would go for road use
