Post by Elektrey on Jun 4, 2015 18:51:53 GMT -5
interesting. Mine is an 8 pole, your r50x is a 6 pole? I wonder what the range of the recall is for because it only lists the 4 pole stator part number (can't even find the other stator kinds anywhere in parts manual) So I went to HF and picked this up Went to hardware store and picked up some bolts and fender washers The washers are the perfect size You can probably see the issue here... Looks like the bolts I got weren't long enough. Will have to run back and get some longer ones. Will keep updated with pics!
Post by Jwhood on Jun 4, 2015 19:25:09 GMT -5
Yes the bolts need too be atleast 5inchs long so you have room try too keep it as even as possible
Post by Elektrey on Jun 4, 2015 19:45:57 GMT -5
Yes the bolts need too be atleast 5inchs long so you have room try too keep it as even as possible Yep I got 6-1.00x40 but they had much larger sizes. You can see in the service manual they have a similar tool 2nd image.
Post by Jwhood on Jun 4, 2015 20:12:44 GMT -5
Yeah but the middle thing is too long
Post by Elektrey on Jun 4, 2015 21:03:54 GMT -5
Tested resistances
Yellow/Blue (Pickup) read 156 ohm Black/Red (Coil) reading 7 mohm
service manual says black/red should read 224kohm(0.224mohm)+/- 20%.
it says nothing however on the pickup. Does this seem reasonable?
Also looks like I'll have to repair this stator as finding a TGB 8 pole stator is pretty much impossible.
Also tested spark plug boot to ground resistance: 12kohm manual says spec 5k-7.6kohm with limit 3kohm.
Post by Jwhood on Jun 4, 2015 22:39:52 GMT -5
I'll keep looking too cause I need a new one also let me know if you find one trey!!
Post by Jwhood on Jun 4, 2015 22:43:14 GMT -5
From what I read on the tech bulliten it says something about just replacing the end I don't know how that would fix it
Post by Elektrey on Jun 4, 2015 22:51:57 GMT -5
Any idea what would cause the resistance of the coil/stator coil to go up by that much? I mean what do I expect when I take off the flywheel. Is it just a simple rewrapping of the ignition coil on the stator?
Jwhood I've given up looking for the stator I don't think it exists. I don't have a part number to search for so it really is impossible to find it. You might have luck contacting harry from whidbeyislandmopeds he probably knows how to get one.
Post by Jwhood on Jun 4, 2015 22:57:07 GMT -5
He can get them but there most likely over $150
Post by Jwhood on Jun 4, 2015 23:42:30 GMT -5
Post by Jwhood on Jun 4, 2015 23:46:34 GMT -5
Told u I would find one!!; )
Post by 90GTVert on Jun 5, 2015 7:46:52 GMT -5
Post by Elektrey on Jun 5, 2015 10:05:21 GMT -5
Well I'm super confused now.
Plug cap showing too high a resistance. Stator Coil showing too high a resistance
checked the two leads going to rectifier from the stator both showed exactly 1.0 ohm
I'm lost I have no idea what the issue is.
Jwhood which CDI did you buy?
Post by Jwhood on Jun 5, 2015 11:34:14 GMT -5
I bought one from aliexpress it was supposed too be adjustable but they sent me a 5 pin non adjustable derestricted parts for scooters has them,scrappys even has one on eBay
Post by Elektrey on Jun 5, 2015 13:39:00 GMT -5
