Post by richard on Oct 7, 2010 20:35:59 GMT -5
can anyone help with trouble shooting a gy6 150cc buggie motor (long case). It loses power as it heats up!!! Its as if it is starving for fuel!!
Post by stepthrutuner on Oct 7, 2010 22:28:15 GMT -5
Make sure fuel lines are routed away from heat sources. Could be caused by a lean condition . Start with an inspection of the intake system. Look for splits or gaps where they shouldn't be between the air filter and the head of the engine. Check vacuum lines. Disassemble the carb and spray it out. If poor running still persists suspect an overly advanced ignition or maybe a warped head. :thumb:
Post by Fox on Oct 8, 2010 8:06:27 GMT -5
