Post by 90GTVert on Oct 14, 2010 15:07:07 GMT -5
The tail/brake light on the Venus has been acting up, in the same way I see lots of Chinese scooter tail/brake lights falter. The socket is getting loose and the bulb can move around a little. Vibration and bumbs can cause the tail light to stop working pretty easily at this point. That's not really safe for anyone, but I ride mostly at night lately so I really need something reliable. I've replaced the socket with an automotive 1157 socket in the SunL with OK results. That worked great for a bit, but it's having a problem here or there now too. I have been much happer with the LEDs I put on T2, and would like to use LEDs here.
I found something that I like, but I'm afraid it may be a little small. I can't find anywhere showing exact measurements of the actual lights, but the whole assembly is just over 3" wide, so I'd have to guess these are 1 - 1 1/4" lights. Not really big enough to make me feel safe.
cgi.ebay.com/ebaymotors/Black-Motorcycle-LED-Tail-Turn-Plate-ALL-IN-ONE-Light-/260672923042
If I could find a couple of 2 to 2 1/2" dual intensity LED lights, I might be able to make something reasonably similar (minus the built in turn signals) at a more acceptable size. The problem is, I can't find any. I can find big 4"+ truck lights that are dual intensity, and 2 or 2 1/2" marker lights that are single intensity. I did find some bullet style lights that would work, but they were more than I would like to spend. I'm hoping to find complete housings, not LED arrays and then buy separate housings. If anyone knows a source for something like this, please share. If you have any other ideas that you think would look cool for cheap (LED only), I'm open to suggestions.
Here's a pic of the back now if it helps. That tail light is about 4"x3" IIRC.
