msb3671
Rock On, Roll On.
Post by msb3671 on Oct 24, 2010 20:04:20 GMT -5
Just wondering... I adjusted the little 'C' clip on my Jet Needle to let more juice in. I'm pretty sure I put it back just how I took it out, but what is the proper sequence to place it back in the diaphragm? Thanks.
Post by 90GTVert on Oct 24, 2010 20:09:50 GMT -5
msb3671
Rock On, Roll On.
Post by msb3671 on Oct 24, 2010 20:16:46 GMT -5
So I drop the needle in first, then the little plate, then screw in the little screw?
Sorry, it's unclear to me. I'm a dolt. Above is how I did it anyways.
Thanks!!!
ADD: If I did do it wrong, could that be a reason for the bad idle and/or loss of power? Thanks again. :clap:
Post by 90GTVert on Oct 24, 2010 20:34:44 GMT -5
Rubber O-Ring (if equipped) Needle/Clip Plate Screw
Make sure the plate is lined up and screwed into the right spot. Somehow I managed to do that wrong one night when I was in a hurry and I had a rough idle.
msb3671
Rock On, Roll On.
Post by msb3671 on Oct 24, 2010 20:40:30 GMT -5
Thanks, friend. I will be checking that tomorrow. I think I did it right, cause I actually used that post today(AWESOME) , but its worth a check. :rockon:
