Post by oldgeek on Dec 6, 2014 18:53:04 GMT -5
Post by oldgeek on Dec 7, 2014 0:13:27 GMT -5
That's amazing that the Vino cases come like that! Dream cases! If you were to trench your own cases would that reed cage work? Does it have the same footprint as other stock reed cages? The reed cages are not interchangeable, the vino cage is bigger. While they look close, I think it would be a lot of work to get it to fit right. If you are interested, you can buy a new one for around $28
Post by oldgeek on Dec 7, 2014 18:04:56 GMT -5
Post by oldgeek on Dec 8, 2014 7:44:08 GMT -5
I'm going to ask a stupid question but is the reason that it special because the reeds align with BDC? Yes, it helps the fuel flow into the transfers. Also the trenching in the case itself improves the flow. Together they improve performance considerably. Sent from my SGH-T999 using proboards
