Post by blaq on Dec 10, 2014 7:28:57 GMT -5
She ran one day the next day no run please help
tvnacman
Post by tvnacman on Dec 10, 2014 9:44:25 GMT -5
check your valves , then check for spark .
John
Post by blaq on Dec 10, 2014 10:35:16 GMT -5
It was running on 0.03 both In N Out the next day it wouldn't startup I just have just did the full on both no luck then I readjusted to 4 in and 5 out still no luck please help
Post by blaq on Dec 10, 2014 10:37:04 GMT -5
It was running on 0.03 both In N Out the next day it wouldn't startup I just have just did the full on both no luck then I readjusted to 4 in and 5 out still no luck please help *I did 4 on both
tvnacman
Post by tvnacman on Dec 10, 2014 11:25:24 GMT -5
MM inch ?
Are you getting spark ? did it stall on you or you shut it down and the next day its a no start ?
John
Post by blaq on Dec 10, 2014 12:38:26 GMT -5
Yes spark and I just readjusted again to 4in 5ex still nothing and I shut it off the last time it ran
Post by blaq on Dec 10, 2014 12:42:21 GMT -5
Its been doing this since bbk install when I bring it back to the mechanic they get it running they give it back I'll use it all day turning off & on but the next day I'm late for work trying to start it I'm getting fed up
tvnacman
Post by tvnacman on Dec 10, 2014 13:06:36 GMT -5
I bet the auto choke is broken .
tvnacman
Post by tvnacman on Dec 10, 2014 13:10:07 GMT -5
do you know how to prime the fuel system ?
John
Post by blaq on Dec 10, 2014 14:20:59 GMT -5
Its been doing this since bbk install when I bring it back to the mechanic they get it running they give it back I'll use it all day turning off & on but the next day I'm late for work trying to start it I'm getting fed up Its a brand new carb that's what the mechanic thought do you know how to prime the fuel system ? John I bet the auto choke is broken .
tvnacman
Post by tvnacman on Dec 10, 2014 14:27:44 GMT -5
Such some fuel into the vac system , if it sputters get the hose back on ASAP .
John
Post by blaq on Dec 10, 2014 15:21:29 GMT -5
Such some fuel into the vac system , if it sputters get the hose back on ASAP . John What would that determine? If its getting gas , just curious
tvnacman
Post by tvnacman on Dec 10, 2014 15:33:07 GMT -5
if you can do it quick and it gets you started in the morning . I guess you could ride to work and not be late .
Post by blaq on Dec 10, 2014 15:52:47 GMT -5
if you can do it quick and it gets you started in the morning . I guess you could ride to work and not be late . I'll try it when I get off work and I'll let you know.
Post by blaq on Dec 10, 2014 15:57:50 GMT -5
If it doesn't work what should I look at next and should I leave the valves @ 4in 5ex it was running on 3in 3ex b4 I change it
