Post by 90GTVert on Nov 6, 2010 15:25:02 GMT -5
What was the choice on the far left? On mine it would be (Left to Right) Headlight On, Running Lights On, Lights Off. Hopefully you haven't just disabled your headlight. lol It may not even be that switch. It could be something powered by that switch, like a bad bulb or socket.
Post by Fox on Nov 6, 2010 16:45:18 GMT -5
Yeah you're most likely right Brent. It's prolly not the switch but whatever is downstream of the switch regarding the far left position.
Post by macman1999 on Nov 7, 2010 23:00:16 GMT -5
mine is the headlight instrument lights and running lights far left with switch only middle is headlight with switch only then it all comes on once the bike is started right is I think headlight only no instrument lights or running lights
so it must be in the switch since it all comes on once the bike is started anyway and the fuse doesn't blow then.
And the oil leak is fixed, I had no idea that the pump would leak if it was out of adjustment and left slightly on by only maybe 1/16 to 1/32"
