larrball
2016 Genuine Scooter Rough House Sport Ti
Post by larrball on Nov 16, 2010 8:09:27 GMT -5
Hey guys i have a cold starter question for ya.
When its cold my starter seems to not catch, until about 2-3 times a try tell it catches. (the drill sound effect) This only happens when its cold (40 deg or less) and it will catch after 2-3 paus'es of the starter until it catches.
At first i thought it could be the bendiex spring but i'd like to know what you all thank. :scoot:
Post by 2strokd on Nov 16, 2010 8:42:59 GMT -5
Battery lose some of its juice from the cold?
Post by 90GTVert on Nov 16, 2010 9:16:37 GMT -5
Sounds like the bendix to me. Since it only happens when it's cold, you could try to put the battery on a charger for a while before starting it when it's cold. That would tell you if the battery had anything to do with it.
Post by stepthrutuner on Nov 16, 2010 10:25:36 GMT -5
Degrease bendix and lubricate with a light oil. Lubricant is too thick and not allowing for free enough operation of your bendix when temps are low.
Post by rocketdog on Nov 16, 2010 13:54:58 GMT -5
I was thinking what ^^^^Step said. Clean it up and lube it.
RD
larrball
Post by larrball on Nov 17, 2010 16:36:03 GMT -5
Thank's guys i did just that. Batt is fine and it is all lubed up. i may have to go with a new bendix.
