Post by spaz12 on Mar 28, 2016 19:44:30 GMT -5
You split a set of cases before, yeah? I'm just wondering if you'll need the case splitter and crank puller/ installer? Those two tools come to mind
Jog-Mania
Mar 28, 2016 20:10:19 GMT -5
via mobile
Post by tsimi on Mar 28, 2016 20:10:19 GMT -5
49ccscoot.proboards.com/thread/13871/5bm-engine?page=2Look at post from October 8. The cases are split already. That crank and the MHR rep cylinder will go into my other 5BM engine. I know that I have to use the hot/cold method to get the bearings in but what about the crank? If I have the installer tool is that gonna work just like that without the hot/cold trick?
Post by spaz12 on Mar 28, 2016 20:24:52 GMT -5
I use the hot cold method but I'm so worried about smacking a crank if it didn't sit right that I bought the installer as well. Had to use it a couple times too to center the crank. But I guess if you're careful you can do it with a plastic mallet. I'm just paranoid maybe?
Jog-Mania
Mar 28, 2016 20:32:37 GMT -5
via mobile
Post by tsimi on Mar 28, 2016 20:32:37 GMT -5
So you're saying I have to use the hot/cold method to get the crank in and evtl use the installer to straighten the crank or can I use the installer all the way from beginning to the end? To get the crank through the bearings is gonna be a super tight fit. Won't that break the bearings?
Post by spaz12 on Mar 28, 2016 20:39:06 GMT -5
Never tried it without heating the cases and freezing the bearings. I don't think I would. My thing is that I don't want to be smacking expensive cranks around with a mallet. That's just me. Several of the other guys have. And you might not even need to. I've had several go together really nice and didn't need to do anything.
Jog-Mania
Mar 28, 2016 21:02:32 GMT -5
via mobile
Post by tsimi on Mar 28, 2016 21:02:32 GMT -5
Sorry to ask again, but just want to make sure. Even if I have a crank installer tool I will have to use the hot/cold method?
Post by spaz12 on Mar 28, 2016 21:05:11 GMT -5
I don't know if you have to, but I do. Seems like less stress on parts.
Post by spaz12 on Mar 28, 2016 21:06:48 GMT -5
Post by spaz12 on Mar 28, 2016 21:08:46 GMT -5
Doesn't look like he did anything other than pull it in with the tool.
Post by tsimi on Mar 28, 2016 21:10:15 GMT -5
lol l just wanted to post the same link to that video. He doesn't use any hot/cold stuff. Just put it over, put on the installer and turn that nut. Making sure the rod isn't getting stuck somewhere.
I guess that is what I am gonna do and see how it goes.
Post by spaz12 on Mar 28, 2016 21:14:41 GMT -5
See if you can borrow/rent the tool from that fancy schmancy scooter shop you visit all the time. The tool is nearly indestructible so there's not much chance of harming it.
Post by tsimi on Mar 28, 2016 21:21:38 GMT -5
I own that tool already. I bought a case splitting and crank installer tool last year because I knew that day will come where I install a crank. Another interesting video here, youtu.be/mpkW3WlZpl0Very interesting is what he starts to explain around 3:10
Post by spaz12 on Mar 28, 2016 21:27:40 GMT -5
Awesome, didn't realize, or forgot, that you had the tool. They're so nice to have. After watching the videos I'll probably not use the hot cold method and just pull them through.
Post by spaz12 on Mar 28, 2016 22:06:25 GMT -5
Damn, scooter attack and maxiscoot are both down. wtf?
Post by tsimi on Mar 28, 2016 22:16:23 GMT -5
Damn, scooter attack and maxiscoot are both down. wtf? Yep! Just wanted to place the order for the crank and the site is down. I probably lost the items inside the cart. Maybe some daily server backup or maintenance. In Europe it is in the middle of night now so best time for them to do such stuff.
