Post by Lucass2T on Mar 29, 2016 2:52:54 GMT -5
Yep that's the one. A beauty isn't she. The Malossi looks very similar. The rod says Malossi and the Stage6 says nothing. Placed order for bearings. NTN 6204C3 2pcs for $5! Thats cheap! I pay €8 for just one!
Post by tsimi on Mar 29, 2016 2:52:54 GMT -5
Yep indeed. I always think why do I have to order Japanese stuff in Europe? Those bearings go from here to there and then back to me here. Japan -> Europe -> Japan
The price for the NSK is $2.60/pcs and the SKF cost $3.50/pcs
Post by tsimi on Mar 29, 2016 2:56:38 GMT -5
Thats cheap! I pay €8 for just one! Still, 2x 8 = 16! which is cheaper then $30 or $40!
06jog
2006 Yamaha Jog
Post by 06jog on Mar 29, 2016 13:53:49 GMT -5
Hi Guys
Sorry to hijack this conversation, wanted to let you know I bought the Yasuni Z pipe to run on the stock Jog for now. I took your advise on the Stage6 BBK and pipe revving higher the the motor would appreciate. Also bought a Malossi Multi Variator (16x13 7g, medium contra), Malossi x special belt, Polini clutch spring set, stage6 adjustable roller set (4, 4.5, 5, 5.5)
Keeping it simple. I will get a Malossi sport 70 BBK later and then a 17.5mm carb after that
Thanks.
Post by spaz12 on Mar 29, 2016 14:28:03 GMT -5
Hi Guys Sorry to hijack this conversation, wanted to let you know I bought the Yasuni Z pipe to run on the stock Jog for now. I took your advise on the Stage6 BBK and pipe revving higher the the motor would appreciate. Also bought a Malossi Multi Variator (16x13 7g, medium contra), Malossi x special belt, Polini clutch spring set, stage6 adjustable roller set (4, 4.5, 5, 5.5) Keeping it simple. I will get a Malossi sport 70 BBK later and then a 17.5mm carb after that Thanks. Get the Athena basic before the Malossi. It's a lot more powerful.
Post by tsimi on Mar 29, 2016 19:09:04 GMT -5
spaz12Did you read the last 1-2 pages? Got me the Stage6 HPC 12mm crank! Plus some 19x15.5 rollers for the Polini variator and a throttle wire and some other small stuff. Paid for the crank 94 Euro!
Post by spaz12 on Mar 29, 2016 19:13:54 GMT -5
I did see that and it's a nice crank. I wish I'd gotten one instead of the overpriced malossi
Post by spaz12 on Mar 29, 2016 19:16:08 GMT -5
Are you serious? 94? That's dirt cheap!
Post by tsimi on Mar 29, 2016 19:39:22 GMT -5
Are you serious? 94? That's dirt cheap! Yep 94! 117-20% Now they raised the price back to 139euro instead of 117 lol
Post by spaz12 on Mar 29, 2016 19:46:21 GMT -5
Wow, you got that job just in time! Sweet.
Post by tsimi on Mar 29, 2016 20:40:31 GMT -5
Wish I would have gotten the $$$ earlier then I could have ordered it together with the 21mm carb and save one time shipping. Still prices were all very good. I am sure when they saw my order they were like "NO! "
Post by birdman on Mar 29, 2016 21:41:50 GMT -5
Sorry Im late to the party but when I installed my crank in the pre-bug motor I used the hot cold method to slide the bearings on the crank then I put the crank with bearings into the cases with no heat or cold of any kind using the Tusk installer tool. It all worked out great.. Also tsimi congratulations on that crank!! I'm soo jealous now
Post by tsimi on Mar 29, 2016 22:15:17 GMT -5
Hi birdman!
I have absolutely no confidence that I can put the bearings all the way down on the crank. What if they should get stuck half way in? I will put the bearings into the freezer over night and then use my heat gun to heat up the case and then just drop in the bearing. Once both bearings are installed into the case I will pull in the crank with the installer tool. That is the plan thus far. I just hope that I don't have to wack the crank with a mullet at the end.
Post by spaz12 on Mar 29, 2016 22:18:13 GMT -5
You have the tool so you won't need to wack it at all.
Post by PIG on Mar 29, 2016 22:32:41 GMT -5
You have the tool so you won't need to wack it at all. That's what she said
