Post by tsimi on Mar 31, 2016 5:47:34 GMT -5
God or a higher being is giving me a sign! I got the Dello 21mm carb today and what do I get? a treatland.tv newsletter with a SALE 16% announcement. Perfect timing to order a few Dellorto parts!
Post by Raizer on Mar 31, 2016 5:49:09 GMT -5
Yes they are meant to have no shields. There open as fuel/oil mix goes through them for lubrication.
Post by spaz12 on Mar 31, 2016 6:23:47 GMT -5
I'm glad someone is having a good day!
Post by tsimi on Mar 31, 2016 18:06:47 GMT -5
The bearings can be installed either way? Or is there a side that has to face the crank?
Post by spaz12 on Mar 31, 2016 18:09:32 GMT -5
Both sides are open, correct? If so then either way.
Post by tsimi on Mar 31, 2016 18:11:37 GMT -5
Yes open both sides. One has text and numbers stamped around the edge the other side nothing. Other then that they seem to look identical.
Post by spaz12 on Mar 31, 2016 18:14:11 GMT -5
Yep, makes no difference.
Post by tsimi on Mar 31, 2016 19:12:44 GMT -5
Thx spaz12! So tell me when are you gonna come over so that we can build this engine together?
Post by spaz12 on Mar 31, 2016 19:14:29 GMT -5
Thx spaz12! So tell me when are you gonna come over so that we can build this engine together? This Nonever!
Post by spaz12 on Mar 31, 2016 19:14:44 GMT -5
Post by spaz12 on Mar 31, 2016 19:15:33 GMT -5
How's it going so far? Pics of the carnage please
Jog-Mania
Mar 31, 2016 19:25:04 GMT -5
via mobile
Post by tsimi on Mar 31, 2016 19:25:04 GMT -5
How's it going so far? Pics of the carnage please I haven't started yet. The crank hasn't arrive yet. As soon the crank arrives I'll start with assembly. I also need the whole gears and gear cover. I am in contact with KN企画 they sell all kinds of gears for the older Jogs and I asked them to check if those older Jog gears fit into mine or not. Otherwise I'll just get me a 2nd hand engine for $50 and take the gears from there. I will take pictures of course and post here. Kinda nervous regarding the bearing installation, what if they won't go in do to too few heat on the case or bearings being not cold enough? I think I could use the crank installer tool to push the bearings over the crank first and then install the crank+bearings into the case. Haven't made up my mind yet. Also need to read about the squish stuff from the link you send once.
Post by spaz12 on Mar 31, 2016 19:39:33 GMT -5
Bearings in the freezer for a few hours and a good heat gun/torch to heat the case halves and you'll be just fine. The damn things just drop right in if the bearings are cold enough and cases hot enough. You'll be fine, promise.
Post by tsimi on Apr 3, 2016 6:40:21 GMT -5
The SJ4000 wi-fi cam is awesome! I put that thing on my helmet and connected it via wi-fi to my phone you can see what you see on the phone display and you can handle the camera from the phone too. Probably something old but I feel like I just witnessed the birth of new technology! Damn, I am getting old I guess. Tomorrow I am gonna take the cam to work. Curious to see whats gonna happen on the way to work.
Post by spaz12 on Apr 3, 2016 10:46:34 GMT -5
Is it bluetooth and does it lag? I'm curious.
On a different note I used mine yesterday and got some footage of the races, but forgot to turn it off (with the cap on) and used up all the memory. I'll be getting more footage this morning though.
