raven
Post by raven on Jan 16, 2015 17:55:41 GMT -5
Could a bad battery make the scooter die when not giving it gas
Post by scooterpimp on Jan 16, 2015 18:23:27 GMT -5
Depends if you have a dc or ac fired ignition , ac system shouldnt cause an issue ,if its your taotao battery shouldnt effect running. (Ac)
Post by stevec on Jan 21, 2015 18:14:17 GMT -5
taotao scooters can be used with no battery and run fine, you may have a vacuum leak or the idle is set too low.
Post by blaq on Jan 26, 2015 9:23:59 GMT -5
Check hoeses see if you have small cracks in them that happened to me and was puzzled
Post by isurffl on Jan 30, 2015 21:27:35 GMT -5
give us some background on its behavior please. like mentioned above, if is a tao tao, the battery doesnt effect its running, only for the starter really, but it will operate a few other things, like your running lamps and fuel gauge, before the engine is running.
