tj
Post by tj on Jan 25, 2015 21:41:12 GMT -5
Post by scooterpimp on Jan 26, 2015 17:36:21 GMT -5
I chopped mine up & made an engine removal stand/ cradle (holds scoot for engine removal) . That thin square tube is tricky to weld!
Post by tenspeed on Oct 19, 2016 20:51:26 GMT -5
Just bolted the bottom back on, flipped it on its side and screwed a 24"x70" piece of plywoon I had laying around to the top (side). Scoot sits on it real nice and it is at a good height to work on. Standing the frame upright would have put the bike too high. No straps or tie down but I feel pretty secure with it just sitting on its stand. It would need a hard hit to knock it over.
Post by 90GTVert on Oct 19, 2016 20:55:48 GMT -5
Post by tenspeed on Oct 19, 2016 21:07:11 GMT -5
Thanks! You have been a huge help to me so far. Just got a 50cc Thunder for my son and am going through it using your PDI videos. Keeping it mostly stock but I am unsealing the carb and changing the fuel line and spark plug/boot. Sealing the electrical connections, changing fluids and adding the magnetic drain plugs...Oh, and valve stems...
Post by dan50 on Oct 19, 2016 22:59:52 GMT -5
I use a lawn mower jack to lift my scooter to work on it. The mower jack holds the scoot real steady if you get the scoot balanced right.
