Post by scooter7878 on Nov 22, 2021 8:11:41 GMT -5
What's your setup? More curious as to jetting. 110 main. 35 idle. 52mm BBK. Long case. I get way better results with the Bando 723-17.5-28 belts. Naraku variator. Naraku drive face. 7g rollers. Yellow contra spring u gotta get into a stroker crank man that bike would rip with a stroker and I can tell u the ssp stroker takes a beating I got over 17,000 miles on my current engine build I beat the balls if my scoot wot I'm seeing over 10,000 I'm probably wot 80 percent of the time it's running strong it added a lot of torque for sure and peace of mind that the stock crank is not in there but to be honest I had 2 other 50mm builds with a stock crank and beat them too well over 10,000 rpm tbh I got more rpm with those set ups stock crank and I got 5,000 on one and 6500 in other and there was nothing wrong they were still going strong when I took apart to freshen up and decided to go stroker. I think with a 26 mm carb I'd gain a bit of top speed and some good power. I'm quite impressed with my current set up my buddy has a vip 150cc with a 155 cc cylinder stock head , performance exhaust,eBay cam shaft,uni pod filter,and a 118mm variator and ssp-g performance clutch,and a 26mm nibbi round slide carb and he accelerates slightly faster and gets about 2 mph top speed than me but he barely pulls ahead of me pretty impressive what u can get from a originally 49cc engine. I'm kicking around ideas to buy one of those 100 dry shot nitrous kit from Amazon and fabricate it so it's a wet system 🤔👀😁. Idk about u but I got 10 inch wheels and 58 to 60 mph is sketchy as hell on 10 inch shit once u creat 47 or so it starts feeling sketchy it's gonna be a rocket with a wet nitrous system. It's already powerful enough if I'm sitting towards back of seat and pin it from a stop it would flip right over backwards if I don't put my weight forward. I think I may invest in a long case and swap parts and some 12 inch wheels before I go nitrous not sure if that frame and wheels are gonna handle much more than what it is now lol
Post by steve1297 on Nov 23, 2021 2:00:49 GMT -5
110 main. 35 idle. 52mm BBK. Long case. I get way better results with the Bando 723-17.5-28 belts. Naraku variator. Naraku drive face. 7g rollers. Yellow contra spring u gotta get into a stroker crank man that bike would rip with a stroker and I can tell u the ssp stroker takes a beating I got over 17,000 miles on my current engine build I beat the balls if my scoot wot I'm seeing over 10,000 I'm probably wot 80 percent of the time it's running strong it added a lot of torque for sure and peace of mind that the stock crank is not in there but to be honest I had 2 other 50mm builds with a stock crank and beat them too well over 10,000 rpm tbh I got more rpm with those set ups stock crank and I got 5,000 on one and 6500 in other and there was nothing wrong they were still going strong when I took apart to freshen up and decided to go stroker. I think with a 26 mm carb I'd gain a bit of top speed and some good power. I'm quite impressed with my current set up my buddy has a vip 150cc with a 155 cc cylinder stock head , performance exhaust,eBay cam shaft,uni pod filter,and a 118mm variator and ssp-g performance clutch,and a 26mm nibbi round slide carb and he accelerates slightly faster and gets about 2 mph top speed than me but he barely pulls ahead of me pretty impressive what u can get from a originally 49cc engine. I'm kicking around ideas to buy one of those 100 dry shot nitrous kit from Amazon and fabricate it so it's a wet system 🤔👀😁. Idk about u but I got 10 inch wheels and 58 to 60 mph is sketchy as hell on 10 inch shit once u creat 47 or so it starts feeling sketchy it's gonna be a rocket with a wet nitrous system. It's already powerful enough if I'm sitting towards back of seat and pin it from a stop it would flip right over backwards if I don't put my weight forward. I think I may invest in a long case and swap parts and some 12 inch wheels before I go nitrous not sure if that frame and wheels are gonna handle much more than what it is now lol I have 12" wheels. I'll go with a stroker when this one goes. Probably going to do gears first. I got up to 53 verified GPS, but yeah, this thing is quick. I pass cars all the time.
Post by steve1297 on Nov 23, 2021 6:21:13 GMT -5
Mines an Ice Bear Ruckus clone(not stretched. Just regular Ruckus). Has no plastic on it, aside from the front, and at your feet.
