Post by beansdaddy78 on Apr 22, 2015 14:08:13 GMT -5
Hey guys. I'm glad I found this site, seems like it's gonna be a ton of help with my project. Having a starting issue on a moped I bought yesterday for $100. With title and 694 miles on it. It's a 2008 bronc door 49cc. The lady said it starts sometimes and she rides it but sometimes it won't. Well so far for me it just won't. It turns odd fine but won't start. Any ideas would be awesome
I look forward to searching this forum for all kinds of info. Thanks guys hope for some help
Post by Florida Antique on Apr 22, 2015 14:14:03 GMT -5
Well I was always told you need 3 things for a gasoline engine to run, gas, compression, and spark. You can check 2 of those by removing the spark plug. If it is wet with gas then you have that, If it sparks when you ground it to the block and turn the engine over then you have that, If you have both, then next step would be a compression check. That should get you started in the right direction.
Post by birdman on Apr 22, 2015 14:55:58 GMT -5
Post by 90GTVert on Apr 22, 2015 14:58:57 GMT -5
Post by scooterpimp on Apr 22, 2015 19:45:01 GMT -5
Post by niz76 on Apr 22, 2015 21:25:45 GMT -5
Is this a 4 stroke? or a 2 stroke?
Post by beansdaddy78 on Apr 22, 2015 22:30:54 GMT -5
Is this a 4 stroke? or a 2 stroke? This scooter is a 4cycle. I can not find any info on This scooter it's a 2008 bronc colt 49cc I havnt been able to find any specs Or anything to tell me what type of not
Post by niz76 on Apr 22, 2015 22:42:00 GMT -5
Is this a 4 stroke? or a 2 stroke? This scooter is a 4cycle. I can not find any info on This scooter it's a 2008 bronc colt 49cc I havnt been able to find any specs Or anything to tell me what type of not If u post a pic (the scooter and also the engine) I betcha someone can tell u lots of info!
Post by Upgrayedd on Apr 22, 2015 22:59:44 GMT -5
welcome aboard
Post by Clank on Apr 23, 2015 3:19:39 GMT -5
Welcome to the forum. Be sure to check out the Tech Library, its full of tons of scooter specs of all makes and brands. You may not find your exact model but I'll bet your engine model is in there... Keep posting and let's us know how it works out in the end.
Post by Sitticuss on Apr 23, 2015 4:01:41 GMT -5
Post by tiny on Apr 23, 2015 4:21:59 GMT -5
Welcome to the insanity
Post by aeroxbud on Apr 23, 2015 5:10:35 GMT -5
Post by runningbuck on Apr 24, 2015 21:23:18 GMT -5
Post by moofus02 on Apr 24, 2015 22:23:50 GMT -5
Welcome
