Post by mmead1971 on May 2, 2015 19:28:33 GMT -5
Tao Tao 50 3 days old. Electric starter worked first night., now have to kick start it. Battery was tested and is good.when i turn the key no lights no nothing. But starts right up with kicker. While bike is running, everything electrical works perfect. Very strange/annoying.worked fine first night almost like i blew a fuse or something. Please help if this sounds familiar.
Post by niz76 on May 2, 2015 20:00:53 GMT -5
WELCOME! Very likely did blow the fuse for some reason or another. It's usually a glass type and located by the battery in small plastic holder.
Post by 90GTVert on May 2, 2015 21:25:16 GMT -5
Post by katastroff on May 3, 2015 6:41:37 GMT -5
hi and welcome
Post by mmead1971 on May 3, 2015 10:19:28 GMT -5
Thank you for the welcome. I will check this in15mins when im done eating.
Post by humanshield on May 3, 2015 10:32:15 GMT -5
Thank you for the welcome. I will check this in15mins when im done eating. Thanks for letting us know what it was. If it's something else, others have pointed out that with new scoots, better to take it back right away than to futz with it too long.
Post by scooterpimp on May 7, 2015 20:08:15 GMT -5
Are we holding the brake lever for e start to work? Sometimes this gets overlooked. ? The fuse Niz mentioned (15amp) i noticed sometimes the clamp part on fuse can be off also.
Post by highmoose on May 9, 2015 0:10:18 GMT -5
good luck
Post by scooterpimp on May 11, 2015 19:33:39 GMT -5
Well? Did ya find the problem?
Post by aeroxbud on May 12, 2015 5:40:03 GMT -5
Welcome
Post by mmead1971 on May 24, 2015 11:16:38 GMT -5
Fuse looked new but took it out anyway. Replaced it- problem solved. Everything works great now. Thanks everyone for the warm welcome and advice.
