Post by burnleycasual1882 on May 10, 2015 10:46:08 GMT -5
I have a Branson 49CC scooter and there's decals on the panels that feel somewhat like they are built in ? I'm after taking them off and replacing them with some other vinyl what's the best method to doing this ? Thanks
Post by oldgeek on May 10, 2015 11:12:30 GMT -5
Careful use of a heat gun worked for me. It softened them up enough to peel them off almost in one piece.
Post by 90GTVert on May 10, 2015 11:33:45 GMT -5
I've only removed them a couple of times, but mine were under a clear coat. I scored around an edge very carefully with a razor just to get it started. I was left with a faint outline of where the decals once were, but it was not noticeable till you got up close. I put new decals over mine and I don't think most people ever noticed. You can kinda see the outlines from the old decal in spots of the pic below. If you look in the C of Cake you can kinda make out the outline of a T. I've heard to use a heat gun quite a few times, just remember a heat gun will get hot enough to melt plastic so use it sparingly.
Post by niz76 on May 11, 2015 8:23:27 GMT -5
I use a heatgun same as oldgeek. If you get it too hot it'll practically melt the decal and come off in a bunch of tiny pieces. Get the heat just right and can pretty much get em off in one piece.
Post by Silar on Jun 23, 2015 13:27:15 GMT -5
I just went through this and had the decals under the clear coat. I used a razor and lifted the edge and peeled it. It was pretty easy. After I got it all off, I then sanded the panel a little to even out the edge from where the clearcoat was at the decal line..
Post by katastroff on Jun 23, 2015 17:16:35 GMT -5
Dynamite. You wont have to worry about leaving a mark in the clear where the sticker was.
Post by tsimi on Jun 23, 2015 17:44:37 GMT -5
I used a hair dryer to warm them up then used the blade of a carpet knife and carefully started to peel of the corners. It works good with "newer" stickers but if you have to remove over 10 year old decals...
Post by horselemonade on Jul 8, 2015 14:17:06 GMT -5
Heatgun from a distance get sticker started reapply heat if its getting stickey again
