xyzm
Post by xyzm on May 12, 2015 14:05:49 GMT -5
An old roommate once told me I messed up my timing on my two stroke (1E40QMB) scooter. I took it apart to the piston, but did not remove the piston.
Somewhere else I read you could'nt mess up the timing if you did not take the piston out
Would just like to confirm from you guys,
Thanks as always!
Post by Elektrey on May 12, 2015 14:20:14 GMT -5
I dont see how you can change the timing unless you are replacing the flywheel/crankshaft.
Post by katastroff on May 12, 2015 14:46:11 GMT -5
Messing up the timing on a 2T takes a lot more work then that, it involves crowbars, hammers, and even explosives.
Post by themajekalbum on May 12, 2015 19:41:15 GMT -5
The only timing you can possibly mess up, with removing the cylinder, is the port timing. To mess it up enough to cause real problems you'd have to put it together with many extra base gaskets. No base gasket wouldn't "mess" the port timing up enough to cause issues, unless it's a highly tuned race machine.
Sounds like your roommate didn't know much about 2 strokes.
Post by humanshield on May 12, 2015 22:02:04 GMT -5
Your roomate wanted your scooter really bad?
Post by stevec on May 13, 2015 9:34:57 GMT -5
i'm still trying to figure out where the valves are so i can adjust them, i tore it all apart and still can't see them and now it won't start.
Post by themajekalbum on May 13, 2015 13:34:41 GMT -5
i'm still trying to figure out where the valves are so i can adjust them, i tore it all apart and still can't see them and now it won't start. If you have a 2stroke motor it will only have reed valves. They go between the intake and the case. Some people tune them by using different thickness of reeds. Generally thicker for higher rpm. Not something that requires regular tuning, once they're set to seal properly you can forget about them. There also isn't a spec, either they seal or they don't.
Post by 2TDave on May 13, 2015 19:01:00 GMT -5
i'm still trying to figure out where the valves are so i can adjust them, i tore it all apart and still can't see them and now it won't start. Steve is pulling your leg. Lmao!
Post by themajekalbum on May 13, 2015 19:51:15 GMT -5
Post by stevec on May 13, 2015 20:07:30 GMT -5
LOL yeah i was pulling your leg sorry. i have the Tomos TSR with the oddball 1E41QMB engine i am putting in a 70cc top end and carbon fiber reeds, also a new performance exhaust because Tomos exhaust only works with a Tomos cylinder if you can find one.
Post by themajekalbum on May 13, 2015 20:17:56 GMT -5
It's all good, I smoked quite a bit before I hit the forum today.
xyzm
Post by xyzm on May 13, 2015 21:23:54 GMT -5
On that Colorado good stuff This same roommate decided to JBweld the drip hole on the bottom of the carb. And I've been looking at new carbs and whats the purpose of the line that goes from the drip hole? He got it to run once, but then my other roommate took it for a ride and it stopped working. All while I was at work.. So after leaving the place I decided to tear it down all the way to really learn about this scoot. This was a yardsale_scooter_paid_40_dollars. Added 285 in parts. Learning how shit works: Priceless _
Post by thatcrazyguy on May 14, 2015 14:53:10 GMT -5
The hose from the drop hole is so gas from the float bowl diesntdrip all over your cvt case & tire, which will attract and hold onto dirt & debris. Can you find a drillbit small enough to drill through the jb weld?
xyzm
Post by xyzm on May 14, 2015 17:00:31 GMT -5
ah cool thanks. I was thinking of leaving it Jbwelded, because before it was dripping constantly.
Post by niz76 on May 14, 2015 17:25:02 GMT -5
ah cool thanks. I was thinking of leaving it Jbwelded, because before it was dripping constantly. if you study the inside of the bowl you'll see the overflow goes down that tube also. If its dripping that could mean that the float is too low..
