Post by 90GTVert on Jan 17, 2011 8:48:17 GMT -5
This is a place to list carburetor and jetting setups that have worked for us. Most likely you won't be able to use someone else's tune for best results, but some of this info could give you an idea of where to start or what ballpark you'll be in with jetting sizes. If you would like to contribute to this database, please PM me. Include as much info as you know. Make, model, year, engine platform, carburetor size, main jet, pilot jet, needle setting, elevation, pre-mix or oil injection (for 2Ts), etc... Thanks!
E-Ton Beamer III
Polini Sport 70cc - Otherwise Stock
- Stock Airbox w/o Snorkel
- Stock Carb
- 95 Main Jet
- 50ft Above Sea Level
- Oil Injection
2008 Keeway Venus Minarelli 2T
- Stock Carb
- 90 Main Jet
- Pre-Mix
Airsal T6 70cc - Leo Vince SP3 Exhaust - Ported Intake - CF Reeds
- Stock Carb
- 85 Main Jet
- Pre-Mix
- Arreche 19mm
- 85 Main Jet
- Pre-Mix
Kymco ZX50 Dio 2T
Ported Stock Intake, Reed Cage, And Intake
- Open Air Filter
- Stock Carb (14mm)
- 97 Main Jet
- 2155ft Above Sea Level
- Oil Injection
2004 Vento Triton Minarelli 2T
MRP 70cc - MRP Tuned Pipe - Otherwise Stock[/b]
- Stock Airbox
- Stock Carb
- 70 Main Jet
- Pre-Mix
2004 Vento Triton 90cc Minarelli 2T
Chinese 54mm BBK - Leo Vince ZX - 25mm Intake - CF Reeds
- UNI Filter
- 25mm DellOrto PHBL
- 98-102 Main Jet
- Pre-Mix
Yamaha Zuma (Pre-Bug) Vertical Minarelli 2T
Ported Stock Cylinder - Leo Vince Handmade - CF Reeds
- Stock Carb (16mm)
- 75-80 Main Jet
- Sea Level
- Oil Injection
E-Ton Beamer III
- Stock Carb
- 95 Main Jet
- Oil Injection
- Stock Carb
- 90 Main Jet
- Pre-Mix
- Stock Carb
- 85 Main Jet
- Pre-Mix
- Arreche 19mm
- 85 Main Jet
- Pre-Mix
Kymco ZX50 Dio 2T
- Open Air Filter
- Stock Carb (14mm)
- 97 Main Jet
- Oil Injection
- Stock Airbox
- Stock Carb
- 70 Main Jet
- Pre-Mix
- UNI Filter
- 98-102 Main Jet
- Pre-Mix
- Stock Carb (16mm)
- 75-80 Main Jet
- Sea Level
- Oil Injection
